Temp questions - Overclock.net
post #1 of 19 Old 04-19-2006, 09:34 AM - Thread Starter
Intel Overclocker
rabies229's Avatar
Quoted: 0 Post(s)
Liked: 12
okay so i have alot of fans in my computer but my temps wont drop
yes im overclocked, But i am still trying to get cooler temps.
okay heres my set up
120mm rear intake (led)
120mm front intake (non led)
120mm top exhaust (nonled)
80mm side intake (led)
modded BT with an led fan
and im in the process of modding 2 of my 5.25" drive bays for another 80mm led intake fan
okay i dont know much about air flow but even after i just added the 120mm fan to the top of my computer i still have the same temps
the 120mm rear fan blows across the bt BUT i with that the bt was mounted differently but i dont know if i can do that
its kind of like this
side
|~(BT)
~=airflow
okay if you have ever looked at the heatsind on the BT its like this
my problem is that the airflow of my 120mm rear is liek this
i would like to have it like this
anyone know if i can turn the BT to fit my needs?
okay as my computer is it is about 36C idle and about 50-52C load
i do believe that i have excess AS5 in there which i am going to change but i need to know if there is any ways that i can turn my fans so i can get better air flow and Better temps
keep this in mind though i have all intake fans and 1 exhaust on the top (heat rises)
also my side 80mm fan blows directly into the bottom right of my big typhoon
and my case is a Dracula X from Logisys
~Rabies
3 nvidia 6600's dead, 2 power supplies dead, 1 7800GS fried--overclocking... Priceless
**Korndog2003 - I have to admit that is a fast celeron** http://img60.imageshack.us/my.php?image=cpuz2uv.png
http://valid.canardpc.com/cache/screenshot/78203.png
rabies229 is offline
post #2 of 19 Old 04-19-2006, 09:42 AM
Forum Manager
Quoted: 2 Post(s)
Liked: 1329
All fans at the back of your case as a rule Should be Exhaust Fans and the ones at the fron should be intakes. The one on top of course should be an exhaust due to the fact the Heat rises.
Welcome to Overclock
ENTERPRISE is online now
post #3 of 19 Old 04-19-2006, 09:48 AM
3.5ghz
Quoted: 0 Post(s)
Liked: 28
The rear fan shouldn't be intaking ... you should turn it around so it's exhausting air. Give that a try and see what happens. The rest of your setup seems ok. Good luck!
Some interesting info to speed up XP:: Info
Try this Crap Cleaner to clean crap off of XP:: CCleaner
Adaware SE
SpybotSearch&Destroy
SpywareBlaster
Maxima is offline
post #4 of 19 Old 04-19-2006, 09:51 AM
Forum Manager
Quoted: 2 Post(s)
Liked: 1329
Its very Imprtant to have a balance of Intakes and Exhausts or the Airflow in your case will be all wrong.
post #5 of 19 Old 04-19-2006, 09:54 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 37
Send a message via MSN to enzo15
i have 2x80mm at the front intake and 2x80mm intake on the side and 1x92mm on the back exhaust and my case temps are 25c with room temps aboutr 20c :]
enzo15 is offline
post #6 of 19 Old 04-19-2006, 09:56 AM
Forum Manager
Quoted: 2 Post(s)
Liked: 1329
Yes also as said above you need to have your Side fan on Intake so leave that one as it is.
post #7 of 19 Old 04-19-2006, 11:21 AM
frostbite's Avatar
Quoted: 0 Post(s)
Liked: 230
Send a message via Skype™ to frostbite
Well really you should have more air being sucked into your case than being blowing out
Roads? Where We're Going, We Don't Need Roads!
frostbite is offline
post #8 of 19 Old 04-19-2006, 01:23 PM - Thread Starter
Intel Overclocker
rabies229's Avatar
Quoted: 0 Post(s)
Liked: 12
ill reverse it in a few min and hopefully ill get some better temps
but does anyone know if it is possible to turn the BT to the way i want for possibly better air flow?
post #9 of 19 Old 04-19-2006, 07:34 PM - Thread Starter
Intel Overclocker
rabies229's Avatar
Quoted: 0 Post(s)
Liked: 12
okay so i reversed the rear fan and it only increased my temps.. my idle was 40C and my load was from 52-58!
i dont know what i should do :S
anyone got any ideas
post #10 of 19 Old 04-19-2006, 08:09 PM
Forum Manager
Quoted: 2 Post(s)
Liked: 1329
depends on where your case is situated in your room aswel.
