Help with SLES 11 folding setup... - Overclock.net
post #1 of 5 Old 08-28-2013, 02:03 PM - Thread Starter
Deeeebs's Avatar
Quoted: 0 Post(s)
Liked: 109
Ok I have a new HP blade (BL460C Gen8) dual E5-2670 that I want to get setup folding. Can anyone help me do this? I have just installed the OS, so next steps are much appreciated. Also helping configure this as a service would be a big plus.
EDIT:
F@H client 6.32 installed/configured/and running.
Anyone know how to make this a startup service? Also make the data available for my HFM.net client to read on my windows box?
Chimp Challenge 3 x Participant  100 Million+ Folding at Home points  Foldathon Folder - 2011 Participant  Foldathon Folder - 2012 Participant  Foldathon Folder - 2013 Participant  500 Million Folding Points
Deeeebs is offline
post #2 of 5 Old 08-28-2013, 06:43 PM
Retired Staff
PR-Imagery's Avatar
Quoted: 0 Post(s)
Liked: 230
For HFM, setup Dropbox on both machines and sync the fahlog.txt and queue.dat files (I make a symlink in a folder in Db so its not syncing the entire f@h work folder) - Dropbox only uses cpu cycles when its syncing a file (i.e. at every step completed, so with the small file sizes, performance hit should be next to nil). Then on the Windows box, point HFM to the Db folder containing those files. Or go through the trouble of setting up a file share over the network to access those files.
"The greatest good you can do for another is not just to share your riches but to reveal to him his own."
Project mATX
PR's Folding Stats
Chimp Challenge 2 x Participant  Foldathon Folder - 2012 Participant  Foldathon Folder - 2013 Participant  100 Million Folding Points  BGB Participant 2014  BOINC Pentathlon 5x Participant   Foldathon Participant 2015  Foldathon Participant 2016  Forum Folding War 2017
PR-Imagery is offline
post #3 of 5 Old 08-29-2013, 05:12 AM
Folding Fanatic
Hacksword's Avatar
Quoted: 0 Post(s)
Liked: 18
Deeeeebs, what OS is the server running?
Hacksword : There's blood on the paper!
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Chimp Challenge Participant  30 Million+ Folding at Home points  Intel Expert Panel  Foldathon Folder - 2013 Participant
Hacksword is offline
post #4 of 5 Old 08-29-2013, 05:53 AM - Thread Starter
Deeeebs's Avatar
Quoted: 0 Post(s)
Liked: 109
SLES 11 SP3... (Suse Linux Enterprise Server)
Deeeebs is offline
post #5 of 5 Old 08-29-2013, 07:20 AM
PC Gamer
d3cryptncompute's Avatar
Quoted: 0 Post(s)
Liked: 2
I would look into this for general instruction through the terminal (everything should be done through the Terminal for folding on Linux). The client is found here. Use -bigadv as an argument to flag bigadv WUs and specify the amount of cores with the -smp flag.
Example:
fah6 -smp 16 -bigadv
Update:
Make a small script with the following:
#/bin/sh
sudo /home/path/to/fah6 -flags -go -here
and put it in your /etc/init.d (guide).
If the script does what it is intended, you can check if you PC is folding with:
ps aux | grep "fah6"
and the output also includes the pid (process id) which can quit the process:
sudo kill PID
** sudo kill -9 PID force quits the process.
d3cryptncompute is offline
