Seems to be a serious problem... - Page 2 - Overclock.net
post #11 of 16 Old 12-15-2008, 06:03 PM
I'm no longer an Asushole
Quoted: 0 Post(s)
Liked: 1299
Were you folding with the ati card?
Chimp Challenge Championship Team  Chimp Challenge Participant  6 Million+ Folding at Home points
grunion is offline
post #12 of 16 Old 12-15-2008, 06:17 PM
Moldder
nafljhy's Avatar
Quoted: 0 Post(s)
Liked: 631
it's always good to do a driver cleaner and what grunion said. if you did, you might have to delete core, work, myfolding, queue, and unitinfo files.
Comp112 likes this.
8 Million+ Folding at Home points
nafljhy is offline
post #13 of 16 Old 12-15-2008, 07:14 PM
Graphics Card Aficionado
jarble's Avatar
Quoted: 0 Post(s)
Liked: 147
Had the same problem had to reinstall windows (when the gtx 260 left it did not like it and decided that I could make do without 2 core's on a quad)
Comp112 likes this.
Chimp Challenge Championship Team  Chimp Challenge 2 x Participant  Foldathon Folder - 2011 Participant  Foldathon Folder - 2012 Participant  750 Million Folding Points  BOINC Pentathlon Participant   Overclock.net 10 Year Member  Foldathon Participant 2017  Forum Folding War 2017
jarble is offline
post #14 of 16 Old 12-15-2008, 08:55 PM - Thread Starter
3.5ghz
Comp112's Avatar
Quoted: 0 Post(s)
Liked: 26
My GSO works fine now, before it was completely bricked.
I was using a 2600XT to fold before, weak I know, but it did SOMETHING.
I reinstall F@H a few times, but is there a config file or something for it I can delete?
EDIT: Fixed THAT problem, found some stuff that needed uninstalled, did that, reinstalled F@H. Starts up now, but is not getting any work, I assume the servers are down or something.
Thanks for the help guys, rep+.
Ninja Edit: Heh, seems like I either have something that is going to take so long, I have no ETA, at all.
Or something else is wrong...
Best Quote Ever (Click to show)Warning: Spoiler! (Click to show)
Commencing operation Separation.
Primary objective: Save my keister
I will make a 50/50 solution of cat water and Vitamin E skin cream to produce a lubricating substance which I will rub on my behind. Then I will commence to lubricate the handle of my sacrificed tooth brush which I plan to use as a pry bar. I will use iTunes and my HD 555s to keep my mind off the task at hand. Once the majority of a cheek is separated I will use a section of a cardboard box from a mini fridge as a spatula.
I'm really nervous.
Comp112 is offline
post #15 of 16 Old 12-16-2008, 08:53 AM
Doomed to see the Future and helpless to change it
Hueristic's Avatar
Quoted: 0 Post(s)
Liked: 432
Windows 7 Beta (6801)
READ this thread before starting your first build!!!
ALWAYS power up a Mobo Before installing it! Consider Less than helpful posts as Free Bumps.
devil-smiley-019.gif¡¡¡ʍʇɟ qn1ɔ uoıʇɐıɔǝɹddɐ 939 ʇǝʞɔos ǝɥʇthumbsupsmiley.pngsozo.gifRetro Rulezsozo.gif
1.
If you can't afford to lose it don't mod or OC it.
2.
At least read the ENTIRE OP before commenting.
Semper Fi
Chimp Challenge Championship Team  Chimp Challenge 2 x Participant  3 Million+ Folding at Home points
Hueristic is offline
post #16 of 16 Old 12-16-2008, 01:28 PM - Thread Starter
3.5ghz
Comp112's Avatar
Quoted: 0 Post(s)
Liked: 26
Works just like Vista .
Everything works the same, only thing I had to do was reinstall one program.
But good point.
I'm really nervous.
Comp112 is offline
