Mass Effect 1 not launching, solutions? - Overclock.net
post #1 of 21 Old 04-24-2013, 01:07 PM - Thread Starter
Jov4nTh3Yu9o's Avatar
Quoted: 0 Post(s)
Liked: 20
Send a message via Skype™ to Jov4nTh3Yu9o
I've posted 2 other threads about the game not being able to launch. It basically goes into an infinite black loading screen after the splash. Just wanted to know if this error log has any meaning to what the problem might be.
0.002] Log: Log file open, 04/23/13 23:03:13
[0.002] Init: BioWare Final Build Version: 1.2.20608.0
[0.002] Init: Command line:
[0.002] Init: Base directory: C:\Program Files (x86)\Steam\steamapps\common\Mass Effect\Binaries\
[0.023] Init: CPU Page size=4096, Processors=4
[0.023] Init: High frequency timer resolution =3.337763 MHz
[0.023] Init: Memory total: Phys=1048575K Pagef=2097151K Virt=2097024K
[5.900] Log: Shader compiling for material Nodebuddy_GOOD took 4.96s
[6.980] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
[6.981] Log: Failed to load 'Material None.': Failed to find object 'Material None.'
Any insight at all?
Before telling me to run ME and Steam as administrator, please do know that I have done this in every possible combination as well as running compatibility.
Jov4nTh3Yu9o is offline
post #2 of 21 Old 04-24-2013, 01:10 PM
No Kill Like Overkill
srsparky32's Avatar
Quoted: 0 Post(s)
Liked: 443
is it a steam game? have you tried verifying the game cache?
srsparky32 is offline
post #3 of 21 Old 04-24-2013, 01:12 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 20
Thats what caused the failure of launching in the first place. Game worked fine before steam forced me to verifycache files. But I have also tried verifying them again, it didn't work.
post #4 of 21 Old 04-24-2013, 01:12 PM
srsparky32's Avatar
Quoted: 0 Post(s)
Liked: 443
Originally Posted by Jov4nTh3Yu9o View Post
Thats what caused the failure of launching in the first place. Game worked fine before verifying cache files. But I have also tried verifying them again, it didn't work.
Tried a reinstall?
post #5 of 21 Old 04-24-2013, 01:16 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 20
Tried a reinstall?
About 5 or 6 times. Nothing seems to work. I installed it on my laptop to test if the game was compatible at all, turns out it runs on my laptop, but I want to play it on my gaming desktop. I don't know what is incompatible with the game or why.
post #6 of 21 Old 04-24-2013, 01:35 PM
srsparky32's Avatar
Quoted: 0 Post(s)
Liked: 443
i know you tried compatability mode, but have you tried vista sp2 or xp sp3 compatability mode? I know i had a problem with running the first mass effect on windows 7 x64 and setting it to xp sp3 did work.
post #7 of 21 Old 04-24-2013, 01:37 PM
srsparky32's Avatar
Quoted: 0 Post(s)
Liked: 443
post #8 of 21 Old 04-24-2013, 04:00 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 20
Tried all compatibility modes, still didn't work.
you may want to try this guy's fix.
I'll give it a shot thanks
post #9 of 21 Old 04-24-2013, 04:10 PM
redxmaverick's Avatar
Quoted: 0 Post(s)
Liked: 38
There is a patch 1.02 on bioware's site. I'd link it but my work blocks game sites. xD
redxmaverick is offline
post #10 of 21 Old 04-24-2013, 04:14 PM
srsparky32's Avatar
Quoted: 0 Post(s)
Liked: 443
try the patch and the sound fix and let us know
