Need help with SimCity 4 - Overclock.net
post #1 of 5 Old 01-20-2006, 08:18 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 40
I'm not familiar with the game and I'm always in the red when trying to develop a town. Can anyone recommend me any tips or sites to get help?
ekul is offline
post #2 of 5 Old 01-20-2006, 08:38 PM
1.3ghz
Quoted: 0 Post(s)
Liked: 18
http://simcity.ea.com/tipstricks/tipsntricks.php there you go everything you'll ever need
RubberDucky is offline
post #3 of 5 Old 01-20-2006, 08:39 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 82
Oh man...been a while since I played the game...
Ummmm, let's see, make sure that there are sufficient connections to your town from neighboring areas. Police, firemen, schools, a number of small clinics and 1 or 2 big hospitals...what else...proper plumbing (ensure they're connected), and power lines. Oh, and also, do NOT build industrial grounds right next to residentially zoned areas...I've learned not to do that from SimCity 2000. Kinda blend from residential to commercial slightly, then have some industry.
Regulus is offline
post #4 of 5 Old 01-20-2006, 10:49 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 40
Thanks.
ekul is offline
post #5 of 5 Old 01-21-2006, 12:13 AM
333mhz
Quoted: 0 Post(s)
Liked: 1
One tip that I've learned with the whole SimNation concept is that residents from one town, can and will work in a different town. What you could try doing is:
Create one town 100% dedicated to residential. The only thing you really need to build in this city zone is Residential, police, hospitals, schools, firehouses, parks, etc. Do NOT build any powerplants, water-works, garbage disposal etc.
Next, start a new city above, or next to the residential city and build nothing but Industrial, police, and firehouses. The edge of the city that's farthest from the residential city is where you want to build all your garbage disposal and Power Plants, you can build your water facilities anywhere you want really, so long as you have some water treatment plants around.
Then, start another city directly connected to Residential. This City will be dedicated to Commercial. All you build here is Commerical, Police, Firehouses, and pretty much anything that increases the land-value such as parks, zoos, lakes, all that crap.
Lastly, you will need to connect these 3 cities in EVERY WAY AVAILABLE, this means, highways, power, water-pipes, subway, rail etc. This is so that your Sims can travel to each zone to work and meet their retail needs, and so that each city also gets its own fill of water, power, and gets rid of its garbage. Each city will make some proposals so that the industrial city sells water and power to residential, which sells it to Commercial. Residential will buy garbage from Commercial, and Industrial will buy all garbage via Residential.
Each city will earn its own amount of money...Commercial and Residential will be able to pay for the power, water and garbage (+ other local expenses) through taxes, and Industrial will earn its money through the Neighbouring deals (+ a little bit of taxes), which'll pay for the massive costs of running water, garbage and power for 3 major cities.
You must only work on each city one little bit at a time, so start off with Residential, build a small amount of the basics, then go to the Commercial, build a little bit, then Industrial, build a little bit more, and so on in that fashion untill you have 3 bustling metropolese.
That's the best advice I can give you (without resorting to inputting cheats). I should submit this to FAQ..what'cha reckon?
That's me on the left...
Domfunkle is offline
