[Solved]Mirrors edge PhysX - Overclock.net
post #1 of 4 Old 04-03-2010, 09:09 PM - Thread Starter
zxo0oxz's Avatar
Quoted: 0 Post(s)
Liked: 66
I tried loading up mirrors edge yesterday, and I was getting an error. After trying compatability and a few reboots, I finally got it to start back up, on normal settings But then PhysX wasn't working like before. I don't think it is doing it on my card properly. It runs okay, until glass breaks, my gpu usage then goes to about 15-20% and my cpu usage skyrockets. I don't get it. I played through like 4 levels with these settings and never had this problem before that. I tried installing/uninstalling it and then putting latest patch. I am stumped.
When all else fails, it's a conspiracy.
zxo0oxz is offline
post #2 of 4 Old 04-03-2010, 09:21 PM
Tator Tot's Avatar
Quoted: 0 Post(s)
Liked: 2154
Tator Tot is offline
post #3 of 4 Old 04-03-2010, 09:35 PM - Thread Starter
zxo0oxz's Avatar
Quoted: 0 Post(s)
Liked: 66
Thanks so much. Deleting the PhysX files from the install folder did the trick. Started it up went to level "Kate" on checkpoint where D there is a bunch of plastic waving in the wind, that completely killed it yesterday, now I am maxed on highest settings locked at 60fps.
zxo0oxz is offline
post #4 of 4 Old 04-05-2010, 01:52 AM
PC Gamer
AbduktedTemplar's Avatar
Quoted: 0 Post(s)
Liked: 6
off topic: i love this game but just like batman aa it slows down in places it shouldnt and i'm guessing its the physx in both =(
By will alone I set my mind in motion.
AbduktedTemplar is offline
