is this a decent psu? - Overclock.net
post #1 of 29 Old 05-02-2011, 09:19 AM - Thread Starter
IXcrispyXI's Avatar
Quoted: 0 Post(s)
Liked: 109
just wondering if this is decent enough to run a 2500k oc'd with 2 560's?
http://www.pccasegear.com/index.php?...ducts_id=12907
Chimp Challenge Participant  10 Million+ Folding at Home points
IXcrispyXI is offline
post #2 of 29 Old 05-02-2011, 09:21 AM
Programmer
Quoted: 0 Post(s)
Liked: 203
Yes, it's a very good PSU and should run that without an issue.
As always, best to get a few more opinions.
I can't remember how much power the 560 uses exactly. But you can't really get much higher quality than SeaSonic.
Plex is offline
post #3 of 29 Old 05-02-2011, 09:24 AM - Thread Starter
IXcrispyXI's Avatar
Quoted: 0 Post(s)
Liked: 109
ok would it be good enough to run some sli kelper gpu's when they come out cause i'm thinkin of gettin 2 of those latter down the track
post #4 of 29 Old 05-02-2011, 09:27 AM
Programmer
Quoted: 0 Post(s)
Liked: 203
We have no idea what kind of power consumption the Keplers will have. No one can realistically answer that for you.
Plex is offline
post #5 of 29 Old 05-02-2011, 09:29 AM
WaterCooler
Traches's Avatar
Quoted: 0 Post(s)
Liked: 61
http://www.jonnyguru.com/modules.php...Story&reid=169
The most in depth PSU review you'll ever need. If jonnyguru signs off on it (which he does), you can trust your life to it...
Anyway 650w should be plenty for a single GPU, SLI it depends on the cards.
LOOP ORDER DOESN'T MATTER.
Chimp Challenge Participant  4 Million+ Folding at Home points
Traches is offline
post #6 of 29 Old 05-02-2011, 09:33 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 51
i would look towards 850 for sli.
Do they think this will help prevent piracy? netflix helps prevent piracy and they are going after it.. WOW. Super job.
Killam0n is offline
post #7 of 29 Old 05-02-2011, 09:34 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 205
I'd step up to the 750W for SLI, but the 650W can cut it.
"The heart has it's reasons that reason knows nothing of."
Princess Garnet is offline
post #8 of 29 Old 05-02-2011, 09:36 AM
WaterCooler
p4p3r's Avatar
Quoted: 0 Post(s)
Liked: 53
Yeah, it's very good.
I would get this XFX 750W Black Edition though. Same insides, I belive. Cheaper.
p4p3r is offline
post #9 of 29 Old 05-02-2011, 09:39 AM
WaterCooler
p4p3r's Avatar
Quoted: 0 Post(s)
Liked: 53
850W is completely overkill.
The CPU = 95W
1x GPU = 170W
Remaining components = 100W
= 535W
Even room for overclock .. It is a good PSU so 650W would be sufficient.
p4p3r is offline
post #10 of 29 Old 05-02-2011, 09:49 AM
TwoCables's Avatar
Quoted: 17 Post(s)
Liked: 6213
The X-650 is the best 650W power supply on the market.
Anyway, even a high quality 550W power supply would be enough to power a system with two GTX 560s in it.
Guru3D.com was able to pull 449W from the wall outlet using Furmark (source). So if we assume 85% efficiency during this power draw, then that would mean that the system was pulling about 381W from the power supply during that power draw.
Therefore, if we add about 150W for the rest of the system (that is, for those times when the entire system is under full load, such as folding on both the CPU and the graphics cards at the same time), we get approximately 530W. However, that's an absolute maximum, not an average power draw. I mean, you'd have to put some real effort forth in order to pull 530W from a power supply with such a setup.
Any high quality 550W power supply is going to have a "continuous" 550W rating, not a "peak" rating. So even if you were to pull ~530W from the PSU for an extended period of time, then that would still be 20W less than the 550W of continuous power the PSU is rated for.
In other words, the SeaSonic X-650 is overkill. It's even overkill on quality.
 Semi-Classic Firefox Add-ons Manager (CSS script)
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
TwoCables is online now
