PSU Longitivity - Page 2 - Overclock.net
post #11 of 12 Old 12-03-2006, 03:07 PM
Super Noob
Delphi's Avatar
Quoted: 0 Post(s)
Liked: 88
Originally Posted by lessthanjake1241 View Post
wow, that thing must be pretty good if its powering a 7800GTX. im pretty certain nvidia reccomends 26 amps for a single 8800GTX, so even though it might work with less i'd reccomend a seperate psu or a new one. the psu's that delphi suggested are perfect, or if you want one that will give you plenty of headroom, check out the Pc power & cooling psu's.
Arent they perfect and yes if you want extream performance go with a PC power & cooling psu those thing are insane
number 1 choice (8800gtx sli capable 60 amps on the 12 rail = insane) PC power & cooling http://www.newegg.com/Product/Produc...82E16817703006
FSP http://www.newegg.com/Product/Produc...82E16817104015
(its not the espilion i think, but its similar)
OCZ 's 700watt 1 http://www.newegg.com/Product/Produc...82E16817341002
600watt 1 http://www.newegg.com/Product/Produc...82E16817341001
These are suggested psu's with alot of head room for more
Delphi is offline
post #12 of 12 Old 12-03-2006, 10:40 PM
4.0ghz
Nasgul's Avatar
Quoted: 0 Post(s)
Liked: 670
Longitivity? I guess it depends on the PSU's rating and under what temps the power is being output. That AKASA has a 75% efficiency which is not bad but definitely, adding a dedicated PSU for the video card will be a great idea if you don't plan on ditching that PSU.
That should even take the work load completely off the PSU from powering the video card at all and it'll probably have a lot less stress then.
Nasgul is offline
