CPU 8 Pin EPS Cable Melted! - Page 2 - Overclock.net
post #11 of 56 Old 04-21-2013, 12:30 PM - Thread Starter
BradleyW's Avatar
Quoted: 0 Post(s)
Liked: 1554
Originally Posted by PedroC1999 View Post
Take my advice and pry the meltings open, from there, inspect the damage
This might not help as such. The PSU can't be used due to this damage. hang on, let me get that image now wink.gif
BradleyW is offline
post #12 of 56 Old 04-21-2013, 12:30 PM
AMD Overclocker
Baskt_Case's Avatar
Quoted: 0 Post(s)
Liked: 62
Ditch the connector and cut and splice the extension if you absolutely have to have it. You'll be all fixed up today.
Personally, I have no problem reaching for my razor blade and black electric tape when working on my PC.
Chimp Challenge Participant
Baskt_Case is offline
post #13 of 56 Old 04-21-2013, 12:39 PM - Thread Starter
BradleyW is offline
post #14 of 56 Old 04-21-2013, 12:42 PM
AMD Overclocker
Baskt_Case's Avatar
Quoted: 0 Post(s)
Liked: 62
Yea, you tapped that connector out! Congratulations! Your an overclocker! wheee.gif
Are you comfortable cutting and splicing?
post #15 of 56 Old 04-21-2013, 12:43 PM - Thread Starter
BradleyW's Avatar
Quoted: 0 Post(s)
Liked: 1554
I'm not sure what to cut exactly without causing uneeded damage to the PSU and killing any chance of an RMA if I can't get it fixed via slicing.
BradleyW is offline
post #16 of 56 Old 04-21-2013, 12:47 PM
AMD Overclocker
Baskt_Case's Avatar
Quoted: 0 Post(s)
Liked: 62
I interpreted from an earlier post that you could not send the PSU back. Forgive me if I am wrong.
Even though, I'm not sure they would approve an RMA on this. Did the PSU come with the extension?
post #17 of 56 Old 04-21-2013, 12:47 PM
If it ain't broke, make it faster
PedroC1999's Avatar
Quoted: 0 Post(s)
Liked: 313
If your covered under RMA, the just RMA it, take 2 7970s out and use a lesser PSU for a while
Chimp Challenge Participant  Foldathon Folder - 2013 Participant
PedroC1999 is offline
post #18 of 56 Old 04-21-2013, 12:51 PM - Thread Starter
BradleyW's Avatar
Quoted: 0 Post(s)
Liked: 1554
Well, in my defence, the cable has been supplied with the intent of use from cooler master to allow connectivity when using their HAF-X, so I don't think I've broken any policy.
Can I not use a pci-e cable for the cpu?
BradleyW is offline
post #19 of 56 Old 04-21-2013, 12:54 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 234
no the EPS connector pinout is completely different.
i like to edit my posts, cause i keep thinking of other things to type. redface.gif
Developing my DIY/Review Youtube channel, search for "ez12a" on youtube. check it out!thumb.gif
Latest Video(s):
H220 unboxing/install, 600T Water Cooled, How to Use SpeedFan, Installing a home network thumb.gif
ez12a is offline
post #20 of 56 Old 04-21-2013, 12:55 PM
AMD Overclocker
Baskt_Case's Avatar
Quoted: 0 Post(s)
Liked: 62
Aren't PCI-e connectors only rated for 75W per connection (I think I'm wrong, but not too far off)? Your CPU is 130W.
Edit, research shows me that 8 pin PCI-e is supposed to be good for 150W. But personally I would not do this, even if the connector fits. Your moving loads around on the PSU and without due diligence in research, no way of knowing if the PSU could handle the power draw with that setup.
It's kinda sketchy.
