How would i go about sleeving the Corsair RM series power supply? - Overclock.net
post #1 of 4 Old 09-14-2013, 08:29 AM - Thread Starter
air tree's Avatar
Quoted: 0 Post(s)
Liked: 0
Well i was looking at the Corsair RM power supplies but i was wondering how annoying or how hard it would be to sleeve the cables and how would i go about doing it? I would use the same kind of regular sleeving on it right?
air tree is offline
post #2 of 4 Old 09-14-2013, 08:48 AM
shilka's Avatar
Quoted: 0 Post(s)
Liked: 2696
if you want a PSU thats quiet then the Be Quiet Dark Power Pro would be a better option then the Corsair RM
shilka is online now
post #3 of 4 Old 09-14-2013, 10:51 AM
Programmer
zalbard's Avatar
Quoted: 0 Post(s)
Liked: 115
You don't know that for sure, RM isn't out yet... Speculation is bad.
BeQuiet is semi-modular, sleeving it would require opening the PSU. Not good.
BTW, Corsair sells sleveed cables for RM if you are lazy. Just so you know.
zalbard is offline
post #4 of 4 Old 09-14-2013, 01:13 PM
shilka's Avatar
Quoted: 0 Post(s)
Liked: 2696
OEM is Chicony Power Technology based on that i would rated them between the HX and AX
Which would make the Be Quiet Dark Power Pro better but also costs more
