PSU volt fluctuation - Overclock.net
post #1 of 3 Old 01-06-2006, 06:31 PM - Thread Starter
4.0ghz
Firefly's Avatar
Quoted: 0 Post(s)
Liked: 40
My new sunbeam has fluctuation on the Vcore. Is it normal? and how far should it fluctuate?
Firefly is offline
post #2 of 3 Old 01-06-2006, 07:00 PM
audio aficionado
soloz2's Avatar
Quoted: 0 Post(s)
Liked: 593
what are you using to measure your Vcore? if you are using cpu-z then I have noticed that the program shows fluctuations often... I do not believe it is anything to worry about.
Current Sound: ODAC > SA Reference IC > Musical Paradise MP-301 6v6 tube amp> Tekton Designs 4.1 loudspeakers
Feedback: Heatware Ebay
soloz2 is offline
post #3 of 3 Old 01-06-2006, 07:06 PM
Now Available in Orange
Fishie36's Avatar
Quoted: 0 Post(s)
Liked: 751
If it's your vcore that fluctuating then that is more likely a fault of the motherboard than the power supply.
Fishie36 is offline
