Upgrade? - Overclock.net
post #1 of 16 Old 06-10-2010, 08:53 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Well first, This is my first post here on overclock.net!
So right now I have a COOLER MASTER Elite 460 RS-460-PSAR-J3 460W PSU, and if I did it correct my system should be in my sig. So you can view everything else there. I plan on upgrading my case to Lian li lancool k-62, my graphics card to HD Radeon 4770, and adding 2 gigs of ram. Now according to Newegg's wattage calculator I will still be able to power all of this. But I don't want to push it too far. Plus, after reading some things I found out the Cooler Master doesn't make good PSUs? I thought they were a pretty solid manufacturer?
Any help would be appreciated, and by looking at the size of this forum there should be plenty.
Kopitar is offline
post #2 of 16 Old 06-10-2010, 09:28 AM
Programmer
JVene's Avatar
Quoted: 0 Post(s)
Liked: 247
Well, Cooler Master makes units that are better than the $25 600 watt units, which aren't what any reasonable person would claim to provide 600 watts (they do, but for only a few seconds before shooting sparks).
The quality of a PSU depends on it's design, the quality of the components selected (particularly the capacitors and transformers), and the execution of it's manufacture.
Cooler Master falls into the region of adequate on these points, but that isn't going to gain much recommendation from enthusiasts who push limits while demanding longevity.
Antec, Corsair and Seasonic are among the favorites, though Corsair more for the company's customer support than specifically their design features. Seasonic makes a number of the other's units.
The power supply is one of those units upon which you may depend through multiple upgrades. They change as they age, especially the capacitors (which stabilize the electronic noise in the power it supplies). Cheaper capacitors age more rapidly, and units loaded beyond 80% of their design age faster than those loaded between 50 and 75%.
The best efficiency is usually found a little over the 50% load mark (as well as it's best noise figures).
As such, if budget allows, it's best to select a unit beyond your common load demand, but not so high that, at idle running, the unit is loaded below the 30% area (where noise usually increases again, efficiency drops again).
The 750 watt unit is a common theme, balanced among these choices, but your demands happen to be a little lower at the moment, and the 650's (or in that region) save some cash.
Some options (I have little experience with some of these, just quick selections).
http://www.newegg.com/Product/Produc...82E16817371031
http://www.newegg.com/Product/Produc...82E16817371015
http://www.newegg.com/Product/Produc...82E16817151096
http://www.newegg.com/Product/Produc...82E16817194049
http://www.newegg.com/Product/Produc...82E16817371021
http://www.newegg.com/Product/Produc...82E16817371026
>>the following Corsair is commonly recommended, but the previous Antec is actually a better choice
http://www.newegg.com/Product/Produc...82E16817139006
http://www.newegg.com/Product/Produc...82E16817371025
JVene is offline
post #3 of 16 Old 06-10-2010, 01:07 PM
Eagle1337's Avatar
Quoted: 0 Post(s)
Liked: 241
What jVene said. I would get a truepower new if it was me. The cooler master elite cannot do it's rated wattage at all. Cooler master makes good cases, some good fans and heatsinks and that is about it.
Eagle's Video Playback Guide
Steam: Deadly55 (will come up as Super Emo Ninja Kamikaze Ninja Prinny or Eagle1337) Origin: Deadly55 Xfire: Deadly55
Eagle1337 is offline
post #4 of 16 Old 06-10-2010, 01:18 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Thanks. I will have to look to see how much I can spend. There is just so much I want to buy and not enough money to spend!
Kopitar is offline
post #5 of 16 Old 06-10-2010, 01:20 PM
Eagle1337's Avatar
Quoted: 0 Post(s)
Liked: 241
give us a price and we will find you the best unit for the price.
post #6 of 16 Old 06-10-2010, 01:21 PM
Fold Among Us
Quoted: 0 Post(s)
Liked: 425
Welcome to the club...
skull.gifFolding Team: The Misfitsskull.gif
SIX TIME CONTINUOUS TEAM COMPETITION CHAMPIONS
VW_TDI_02 is offline
post #7 of 16 Old 06-10-2010, 01:35 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Free.....haha.
Well around $70 is what I'm looking at. If I buy the PSU now (which it
looks like I am considering I'll need it to buy the graphics card anyway) then I'm going to have to be patient and wait to upgrade the graphics card, ram, or case.
Kopitar is offline
post #8 of 16 Old 06-10-2010, 01:55 PM
Eagle1337's Avatar
Quoted: 0 Post(s)
Liked: 241
Blam here you go.
post #9 of 16 Old 06-10-2010, 07:05 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
So 550 watts should be fine?
Kopitar is offline
post #10 of 16 Old 06-10-2010, 07:17 PM
Eagle1337's Avatar
Quoted: 0 Post(s)
Liked: 241
easily. Look at my sig rig.
A q2555, and a 5870 uses only 380w on load.
