Does my power supply look weak - Overclock.net
post #1 of 13 Old 03-01-2006, 08:09 AM - Thread Starter
4.0ghz
PGT96AJT's Avatar
Quoted: 0 Post(s)
Liked: 79
Using speed fan I was able to get the graph of the 12V rail during the test. The voltage seemed to drop real low and be all over the place (and I wan't overclocking). Its an aspire concord 420W with at least 30A on the 12 v rail (I can't remember exactly)
8 Million+ Folding at Home points
PGT96AJT is offline
post #2 of 13 Old 03-01-2006, 09:12 AM
Retired Staff
ncsa's Avatar
Quoted: 0 Post(s)
Liked: 657
Look in BIOS and se what that reports but the best way is to check using a multimeter ... do this when the system is Posting, OS Idel and OS Load.
If it drops alot then the PSU needs to be changed out.
11.4v is low and on the lower limit of the ATX12V design spec. Aspire PSUs are not known to be true to their rating --- unlikely to deliver 30A on the 12V rail.
ncsa is offline
post #3 of 13 Old 03-01-2006, 09:14 AM
PC Gamer
Renegade5399's Avatar
Quoted: 0 Post(s)
Liked: 224
It looks as weak as the one I am running in one of my folding rigs. All other voltages are ok, but the 3.3 is 3.1 and the 12 is ~11.5. I am stable, but I fear it is limiting the OC. 11.4 is kinda low though.
My Sauce Is Much 13373|2 Than Yours
I am made of Win.
Renegade5399 is offline
post #4 of 13 Old 03-01-2006, 12:10 PM - Thread Starter
4.0ghz
PGT96AJT's Avatar
Quoted: 0 Post(s)
Liked: 79
well at idle speedfan is saying around 11.6 volts...but they bios says 11.4. so that means my load voltages my even be lower then 11.4 volts. i guess having 4 hard drives, 2 optical drives and a 6800gs finally took its toll on it.
i think i'll replace it with this:
http://www.newegg.com/Product/Produc...82E16817103459
PGT96AJT is offline
post #5 of 13 Old 03-01-2006, 12:35 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 224
Why not go with this for just a few dollars more? It more powerful, SLi approved, and best of all, modular!
EDIT: Just noticed it's out of stock. Try this.
I am made of Win.
post #6 of 13 Old 03-01-2006, 12:44 PM - Thread Starter
4.0ghz
PGT96AJT's Avatar
Quoted: 0 Post(s)
Liked: 79
those look like possibilities but I dont plan on running SLI anytime in the near future.
i noticed you have a rosewill psu in your profile. are the voltages stable on them because they seem to be good deals.
PGT96AJT is offline
post #7 of 13 Old 03-01-2006, 12:58 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 224
They are an excellent buy if you're not going to be running SLi! I purchased this PSU due to it's price and power ratings. Let me say I could not be happier. I have all the equip you see in my specs plus 2x 10,000 RPM 36GB SCSI Barracudas, and 2 optical drives. Lump that in with all my case fans and me being OC'ed and you can see it's a good supply. It's heavy too, not some flimsy little POS.
And finally, here's some
I am made of Win.
post #8 of 13 Old 03-01-2006, 01:12 PM
4.0ghz
NOS---'s Avatar
Quoted: 0 Post(s)
Liked: 108
Never trust Software.
Pull out a volt metter and check the voltages yourself, the yellow is +12v and the Blacks are grounds.
NOS--- is offline
post #9 of 13 Old 03-01-2006, 01:52 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 224
NOS - The voltages you see there are almost the same as in my BIOS. Using a voltmeter and checking the voltages in the BIOS are almost the same. Not to mention, I'm not about to open my case to check voltages on a supply that has been 100% stable for me for like 8 months now. If I had just got this PSU, I would agree, but there's no need when the track record backs up the readings.
I am made of Win.
post #10 of 13 Old 03-01-2006, 02:45 PM - Thread Starter
4.0ghz
PGT96AJT's Avatar
Quoted: 0 Post(s)
Liked: 79
are rosewills loud? some of the reviews on newegg people complain about them being loud
PGT96AJT is offline
