Cooler Master Elite 130? - Page 14 - Overclock.net
post #131 of 177 Old 12-09-2013, 03:12 PM
CptAsian's Avatar
Quoted: 0 Post(s)
Liked: 55
The fan, by default, is in intake fan, and it should stay like that, in my opinion. I don't see a reason why it should be an exhaust fan.
Sorry to be a grammar Nazi here, but "outtake" is only used for blooper type stuff. tongue.gif
http://dictionary.reference.com/browse/outtake?s=t
I always like to get on my friends about that.
Clubs (Click to show)
Quotes (Click to show)
Straigtened the pins using a sewing needle and magnifying glass and all was well. Apart from two days later the cpu died completely.
I don't think I've ever operated a hoe between my legs before, so yeah, I'd say it does.
250 Million Folding Points  Foldathon Participant 2017  Forum Folding War 2017
CptAsian is online now
post #132 of 177 Old 12-09-2013, 09:25 PM
gsd17's Avatar
Quoted: 0 Post(s)
Liked: 0
I just got this case as well, very happy with it. I noticed it was missing the watercool port that was picture in the preview. Not sure if different version are sold?
Anyone doing a custom loop with this case? I almost went with the EK-CoolStream PE 120 or XSPC AX120 but decided to keep it simple with the Cooler Master 120XL instead.
gsd17 is offline
post #133 of 177 Old 12-11-2013, 01:26 AM
Case Modder
Liquored's Avatar
Quoted: 0 Post(s)
Liked: 5
yes since the elite 110 is too small for my rads im moving that build into my elite 130 case. just waiting for the pump and the rest of the parts for the 110 to make the migration.
Liquored is offline
post #134 of 177 Old 12-11-2013, 01:32 AM
WaterCooler
seross69's Avatar
Quoted: 0 Post(s)
Liked: 224
Good to see some builds using this with water cooling. I plan on this also but will not have a GPU in this system as no need for it..
No trees were harmed in the sending of this message. However, a large number of electrons were terribly inconvenienced
Just playing with cooling and Computers
seross69 is offline
post #135 of 177 Old 12-17-2013, 01:56 PM
HuwSharpe's Avatar
Quoted: 0 Post(s)
Liked: 28
Originally Posted by IllusionistBRS View Post
How well did the H80's rad fit? You said that you had to cut some plastic off the fan.
Originally Posted by tmaven View Post
Pretty well, if you will remove dvd bay. If not, you have to cut two "hooks" from dvd bay from bottom
I have just fitted a H80 in an Elite 130 no problem. I didn't have to remove or cut anything. Just saying.
HuwSharpe is offline
post #136 of 177 Old 12-17-2013, 02:39 PM
WaterCooler
seross69's Avatar
Quoted: 0 Post(s)
Liked: 224
I put a UT60 in mine with no problems.. see
seross69 is offline
post #137 of 177 Old 12-17-2013, 02:44 PM
Quoted: 0 Post(s)
Liked: 4
Are you using 2 fans?
Inside fan was in collision
tmaven is offline
post #138 of 177 Old 12-17-2013, 02:47 PM
WaterCooler
seross69's Avatar
Quoted: 0 Post(s)
Liked: 224
I could have used push pull but it would have been a little tighter and did not need it.
seross69 is offline
post #139 of 177 Old 12-17-2013, 03:07 PM
HuwSharpe's Avatar
Quoted: 0 Post(s)
Liked: 28
I have the H80 with 2 fans in push/pull and i have no trouble. Perhaps it is only possible when installing from one side? I installed the cooler from the right side of the case (as you look at it from the front).
Of course when you mount a radiator at the front the question has to be intake or exhaust.... I have chosen exhaust, makes no sense to push hot air inside the case, but that's just my opinion.
post #140 of 177 Old 12-18-2013, 10:46 AM
HuwSharpe's Avatar
Quoted: 0 Post(s)
Liked: 28
Just thought i would share a photo of my Cooler Master Elite 130 thus far, fitted with a Bitfenix Recon fan controller, which is used to control all system fans and the code cathodes fitted at the front of the case, i know been able to turn lights on and off over the internet using a mobile device is somewhat pointless, but some things you do just because you can. I have a Corsair H80 fitted in the front with 2 Phanteks PH-F120S fans, in an exhaust configuration. In addition to this i have also removed the standard feet and fitting 4 Pulse Modding Aluminium Case Feet.
Still plenty of things to do with the case, one of which is stop light leaking out on spaces on the front panel, though the blue lit USB port looks okay.
