Corsair Carbide Air 240 Owner's Club - Page 148 - Overclock.net
post #1471 of 3783 Old 10-16-2015, 10:20 AM
Coldashbin's Avatar
Quoted: 0 Post(s)
Liked: 0
Corsair Air 240
Intel 5820k @ 4.2Ghz
EVGA X99 Micro 2
XSPC RX240 v3
EK Supremacy Evo
EK X-Res 100 with D5 Vario
EVGA GTX670 FTW
Coldashbin is offline
post #1472 of 3783 Old 10-17-2015, 12:54 AM
gary66's Avatar
Quoted: 0 Post(s)
Liked: 0
Yes it fits, I wish I could get you the link but I made a list of all TI's that fit through a lot of research. I believe you can mount it top right or front right depending on your setup (looking in through the window)
Hybrid is basically a Reference card with some tubes sticking out, you can bend them enough, it might be on the window a little bit but it should fit.
If anyone else is interested in the list here it is.
List of GTX980 ti that fit in Corsair Air 240(Height)
Palit GeForce GTX 980 Ti Super JetStream
EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+
EVGA GTX 980ti Hybrid
Gigabyte GTX 980 Ti G1 Gaming SOC
gainward 980ti phoenix
Evga 980ti hybrid
zotac 980ti amp
Inno3d 3x
Inno3d 3d 4x
inno 3d hybrid.
980ti Reference Cards
gary66 is offline
post #1473 of 3783 Old 10-17-2015, 03:32 AM
4.0 GHz
Quoted: 0 Post(s)
Liked: 37
Originally Posted by Coldashbin View Post
Corsair Air 240
EVGA X99 Micro 2
XSPC RX240 v3
EK Supremacy Evo
EVGA GTX670 FTW
LocutusH is offline
post #1474 of 3783 Old 10-17-2015, 08:53 AM
Coldashbin's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by LocutusH View Post
Thanks, had to do some minor case mods with my dremel to get the RX to fit, the rad fan holes didn't line up with the case ones and I had to create extra clearance at the top of the case for the rad top fill ports. Happy with the result though, low resistance rad means only need to run push fan configuration. The Res fitted below the SSD drive cage as well!
post #1475 of 3783 Old 10-18-2015, 04:12 AM
spulse's Avatar
Quoted: 0 Post(s)
Liked: 0
thanks - it''s good to know it'll fit - where would be a good place to fit the rad/fan?
spulse is offline
post #1476 of 3783 Old 10-18-2015, 05:27 AM
Toasty Raymaker's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by Toasty Raymaker View Post
has anyone used a Magicool DCP450 pump/res combi, do you know if it would have enough power to cool an EVGA GTX980 ti Hydro Copper as well as a 5930k cpu on a loop with an XSPC RX240 rad?
https://www.overclockers.co.uk/showproduct.php?prodid=WC-025-MA&groupid=962&catid=2133&subcat=1845
Disregard this, i've found a D5 pump/res that'll do the job...
Toasty Raymaker is offline
post #1477 of 3783 Old 10-19-2015, 01:57 AM
Commodore 64
plainfaced's Avatar
Quoted: 0 Post(s)
Liked: 0
Hi All.. Noob here.. After a good 5 years without a PC, ive sourced some parts and built myself a moderate Gaming PC.... With what I think is the best looking case on the market!
Photos to come.. I did have two questions though.
1. Did anyone have trouble with the front panel connectors (pw switch, reset etc)?? I had crazy problems during my build (and still do if I play around with things) - Where my PC would power up for a second, then die... After much troubleshooting, I'm thinking its a short somewhere - Something is causing the PSU to cut... So, I removed the HDD LED and PW LED - and what do you know - The PC powers up fine..
Strange..
2. With the space in the rear for the 80mm fans - Is it OK to have ONLY intake fans? - ie, two at the front and one at the top.... So the three fans push air into the case, and its forced out the back?
Thanks in advance.
plainfaced is offline
post #1478 of 3783 Old 10-19-2015, 02:15 AM
4.0 GHz
Quoted: 0 Post(s)
Liked: 37
Yeah, you should be fine with intake only. Just remember to put somethin in the lower compartment for the HDD's too. Thy get very hot in there, if they have no airflow.
Isnt that L9i a bit too small for the 4790?
LocutusH is offline
post #1479 of 3783 Old 10-19-2015, 02:32 AM
Commodore 64
plainfaced's Avatar
Quoted: 0 Post(s)
Liked: 0
The side compartment? PSU, cables etc? - Yeah I'm only running SSDs.. So hopefully wont get too hot.
Seems to do alright.. I pushed the CPU a little.. It certainly looks to perform better than the stock cooler.. And.. I know this is an OC forum.. But I deliberately got the standard 4790 (not K) So I wouldn't overclock.. Just wanted this to be a standard build for gaming.
post #1480 of 3783 Old 10-19-2015, 05:11 AM
Coldashbin's Avatar
Quoted: 0 Post(s)
Liked: 0
when benching, my 3 WD Reds used to heat up a lot in the rear 3.5" cage. I've fitted a 60mm fan just inside the rear vent panel which draws cool air in from the back and across the drives. Works a treat, 60mm fan fits OK, I mounted using the rubber fan isolation mounts.
