Sound Blaster Audigy 2 ZS or ASUS XONAR_DG 5.1 Channels recommendations for under 50$? - Overclock.net
post #1 of 2 Old 09-05-2012, 08:32 PM - Thread Starter
abablitz's Avatar
Quoted: 0 Post(s)
Liked: 2
Hi, I'm new to sound cards and was wondering if it really makes that big of a difference between the a dedicated and a integrated? How would you compare it to the sound chips in the iphone 4 etc? I have a pretty good set up for headphones and was just wondering what would get me the most quality for the best value. Thanks.
http://www.amazon.com/gp/customer-media/product-gallery/B0000CG4DI/ref=cm_ciu_pdp_images_0?ie=UTF8&index=0&isremote=0
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
abablitz is offline
post #2 of 2 Old 09-05-2012, 08:51 PM - Thread Starter
abablitz's Avatar
Quoted: 0 Post(s)
Liked: 2
Also I have the asrock p67 extreme 4 gen 3 motherboard, compared to integrated how good are these cards?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
abablitz is offline
