Looking to increase recording quality - Page 3 - Overclock.net
post #21 of 29 Old 08-14-2013, 06:25 PM
TwoCables's Avatar
Quoted: 12 Post(s)
Liked: 6212
Originally Posted by eosgreen View Post
ok so the snowball picks up my keyboard (bought one to try it out at best buy.
are there, and i hope im saying this right, uni-directional mics like this?
The reason it's picking up your keyboard is due to being a large diaphragm condenser mic. It's like a speaker phone, only a speaker phone is a small diaphragm condenser.
 Semi-Classic Firefox Add-ons Manager (CSS script)
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
TwoCables is online now
post #22 of 29 Old 08-14-2013, 10:38 PM - Thread Starter
4.0ghz
eosgreen's Avatar
Quoted: 0 Post(s)
Liked: 38
i guess then the thing i want is a higher quality clip on mic and in a perfect world wireless clip on mic or headset mic that wont have static or any other noise issue when recording
eosgreen is offline
post #23 of 29 Old 08-15-2013, 05:24 AM
Fan Man
DVLux's Avatar
Quoted: 0 Post(s)
Liked: 40
Are you sure it's not because of the pattern it's using?
Also, you can't really get "High quality" in a clip mic. Good electronics do require space.
Meow?
DVLux is offline
post #24 of 29 Old 08-15-2013, 07:07 AM - Thread Starter
4.0ghz
eosgreen's Avatar
Quoted: 0 Post(s)
Liked: 38
hm ok so what are my options for good mics that wont pick up my mouse clicks or keyboard types
eosgreen is offline
post #25 of 29 Old 08-15-2013, 08:30 AM
Fan Man
DVLux's Avatar
Quoted: 0 Post(s)
Liked: 40
Any cardioid patterned mic should work, technically, assuming it's not facing your keyboard, and/or you aren't using a loud mechanical keyboard...and assuming you don't have anything else behind you. The Yeti can do Cardioid, if you set it up properly.
Meow?
DVLux is offline
post #26 of 29 Old 08-15-2013, 02:28 PM
TwoCables's Avatar
Quoted: 12 Post(s)
Liked: 6212
The pattern it's using is not going to determine whether or not someone gets static.
Static is a sign of either electronic interference, or a poor cable connection at some point along the cable. Or, it could even be a problem with the mic itself and not the cable. Either way, it has nothing to do with the pickup pattern.
post #27 of 29 Old 08-15-2013, 03:06 PM
Fan Man
DVLux's Avatar
Quoted: 0 Post(s)
Liked: 40
Meow?
DVLux is offline
post #28 of 29 Old 08-15-2013, 03:08 PM
TwoCables's Avatar
Quoted: 12 Post(s)
Liked: 6212
Well, I mean think about it: what is the pickup pattern? What makes the pickup pattern become the pattern that it is? How could any pickup pattern result in static?
post #29 of 29 Old 08-15-2013, 10:42 PM
First Time Build
cuad's Avatar
Quoted: 0 Post(s)
Liked: 127
To the OP,
You were using a Zalman. I had one of those mics before, and they are crap. You were right to get a new microphone. The posters in this thread were right to recommend a USB microphone since they're the most cost-effective option. All microphones that sit on your desk are going to pick up annoying thuds from your keyboard. One thing you can try is adding a shockmount to your set up. Shockmounts are designed for these circumstances, so they should work, but I can't guarantee it since I've never tried one.
You say you bought the snowball from Best Buy, so I'm assuming it cost you $70. Amazon sells the shockmount for that microphone for $40. It has some awful reviews though. :/
This set up here has a similar price but better ratings. http://www.sweetwater.com/store/detail/C01USBPak
cuad is offline
