hooking up ps3 spdif out to sound card, no sound from speakers, please help - Overclock.net
post #1 of 7 Old 09-22-2013, 10:07 AM - Thread Starter
cruelntention's Avatar
Quoted: 0 Post(s)
Liked: 15
Hello All
As the title says, I'm in need of some help that I thought would be easy. Currently I have my PS3, hooked up HDMI to my Dell U2713HM, after that I have the optical cable(spdif) from the PS3 into my SoundBlaster Z optical in port. I've plugged my green speaker cable into every single hole on that card and no sound is coming out of it. I'm beginning to think that I need an optical out cable running to a receiver in order to get sound coming out...something I hope isn't true, can someone please help me with this issue?
Corsair Graphite Club
cruelntention is offline
post #2 of 7 Old 09-22-2013, 10:48 AM
Audiophile
Tiihokatti's Avatar
Quoted: 0 Post(s)
Liked: 256
Check windows sound/recording devices, for example when using ps3 --> line-in you need to check "listen to this device" box from the line-in settings (in the windows sound panel, not soundcard panel).
Ppl should learn to add more info to their posts when they ask for help...
OCN Anime/Manga Club
[Official] OCN Headphones and Earphones Club
Tiihokatti is offline
post #3 of 7 Old 09-22-2013, 11:11 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 15
Hey Tiihokatti
I don't see where it says listen to this device in sound/recording, although at recording under digital-in, the green bars are all the way up, but in playback and sounds tab, there is nothing.
post #4 of 7 Old 09-22-2013, 11:16 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 15
okay, I found the "listen to" that you were talking about, I enabled it and pointed it towards the speakers...however all I hear is static, not like static from a bad connection on a phone, but it was more of repetitive noise at a fast rate. know what could be causing that?
post #5 of 7 Old 09-22-2013, 11:40 AM
Audiophile
Tiihokatti's Avatar
Quoted: 0 Post(s)
Liked: 256
If you hear static, most likely the ps3 has DTS/DDL! encoding on while the soundcard has it off.
Same thing happened when I plugged my xbox360 with optical to MS40 speaker DAC, switched the DDL! off and everything was working.
If you only use stereo speakers, just turn the DDL!/DTS off from the ps3. It's useless for you.
cruelntention likes this.
post #6 of 7 Old 09-22-2013, 12:13 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 15
the speakers i'm using are z623...i'm guessing they're just stereo speakers huh? another question if you know...are the z623's good to use a simple speaker set up for a tv?
thanks for all the help! +rep!
post #7 of 7 Old 09-22-2013, 12:58 PM
Audiophile
Tiihokatti's Avatar
Quoted: 0 Post(s)
Liked: 256
Well... The little audiophile inside me is yelling "burn them in hell!", but I would say they are decent for that kind of use (if the price is right, as m-audio AV40 and Behringer MS40 are cheaper here in Finland).
