Speaker Static Buildup - Overclock.net
post #1 of 4 Old 10-04-2016, 05:55 PM - Thread Starter
Fleacircus's Avatar
Quoted: 0 Post(s)
Liked: 1
I just finished my latest pc build and I'm using the same 5-channel speakers from my old build. However, this time after connecting the orange, green, and black cables to the corresponding motherboard headers, I've noticed a lot of what i think is static build up on the case and in the speakers. This usually happens after I've let the computer sleep for an extended period of time. When i power on again, the speakers pop like when you slap a mic on stage. This didn't happen with the last computer.
Is this bad and how do i stop it?
Thanks
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance
Fleacircus is offline
post #2 of 4 Old 10-06-2016, 05:51 AM
frostbite's Avatar
Quoted: 0 Post(s)
Liked: 230
With speakers id say its a bad earth but being a pc, is the correct driver installed and its definatly set to 5.1
It could be a feedback loop like connecting an active speaker to a balanced output and not a pre out
Roads? Where We're Going, We Don't Need Roads!
Overclock.net 10 Year Member
frostbite is offline
post #3 of 4 Old 10-08-2016, 09:25 PM - Thread Starter
Fleacircus's Avatar
Quoted: 0 Post(s)
Liked: 1
Bad earth?
The correct driver is installed.
How do I verify whether the speakers are set to 5.1?
The speakers are connected to the same ports as the last computer which didn't have this problem.
post #4 of 4 Old 10-08-2016, 09:52 PM
Quoted: 2 Post(s)
Liked: 44
Could be a crappy mobo too....
whitrzac is online now
