Audio/Video Receiver - Overclock.net
post #1 of 7 Old 02-25-2008, 07:51 AM - Thread Starter
SeanEE89's Avatar
Quoted: 0 Post(s)
Liked: 13
Lately I have been thinking about buying a Audio/Video receiver and getting some speakers to go with it. I know I could just use the regular computer speakers that I have but I plan on hooking my PS3, Xbox 360, Wii and PC all to my new Dell 24" and I don't have enough audio connections in my sound card to support all of the systems so I believe my only solution is to get a good audio/video receiver.
If anyone else has some ideas or could recommend a good receiver that will support 1080p video through HDMI for my PS3 and Component for my 360 I would really appreciate it.
SeanEE89 is offline
post #2 of 7 Old 02-25-2008, 08:30 AM
1.3ghz
Quoted: 0 Post(s)
Liked: 15
I'd get the Onkyo HT-SR800.
You can get the system for about $400 and it does 7.1 w/ hdmi. You have to run separate optical for sound or coxial. Also if you do component input then it has to be component output.
If you want something a little more future proof for recievers, I'd get the onkyo 605. That way you can decode the Dolby TrueHD or DTS-HD Master from bluerays. It also does pass through from component to HDMI and uses HDMI 1.3. HDMI 1.3 allows you to get sound from the hdmi cable instead of having to run another optical cable w/ it. They both get the same quality sound, but hdmi has more bandwidth. For example, I don't think you can run the trueHD or DTS-hd over optical.
balake777 is offline
post #3 of 7 Old 02-25-2008, 08:46 AM - Thread Starter
SeanEE89's Avatar
Quoted: 0 Post(s)
Liked: 13
According to what I read about the onkyo 605 it can convert analog to HDMI although TrueHD and DTS-HD aren't supported yet by any video players are they? and Im guessing the PS3 wouldnt support them either?
SeanEE89 is offline
post #4 of 7 Old 02-25-2008, 08:53 AM
4.0ghz
smokinbonz's Avatar
Quoted: 0 Post(s)
Liked: 111
What are you looking to spend. That looks like a nice unit to me for what you plan on using it for. I wouldnt think about true HD and DTS HD Its a joke - Hello Marketing. Yeah im gonna have 14 + speakers in my living room. If you can swing the jing Integra made by Onkyo makes Nice receivers also.
smokinbonz is offline
post #5 of 7 Old 02-25-2008, 08:59 AM - Thread Starter
SeanEE89's Avatar
Quoted: 0 Post(s)
Liked: 13
I am looking to try to spend a max of $500 but I would like to keep it as low as possible. A 1/4 Jack for my Sennheiser headphones would be a big plus as well so I wont have to use the annoying 1/4 to 1/8 adapter anymore.
SeanEE89 is offline
post #6 of 7 Old 02-25-2008, 09:03 AM
1.3ghz
Quoted: 0 Post(s)
Liked: 15
yea, i don't know anything that uses it yet, but dolby sounds good enough to me. I think you'd need really good speakers to be able to tell the difference. From what i was told, it's just less compressed like wav vs. mp3 or something. I'd just stick w/ the sr 800 for what your doing.
post #7 of 7 Old 02-25-2008, 09:25 PM
audio aficionado
soloz2's Avatar
Quoted: 0 Post(s)
Liked: 593
I'd get a refurb Onkyo receiver from shop onkyo and a pair of x-ls from av123.
Current Sound: ODAC > SA Reference IC > Musical Paradise MP-301 6v6 tube amp> Tekton Designs 4.1 loudspeakers
Feedback: Heatware Ebay
soloz2 is offline
