How do you skin Foobar2000 - Overclock.net
post #1 of 7 Old 03-20-2008, 07:08 PM - Thread Starter
Audiophile
Lemondrips's Avatar
Quoted: 0 Post(s)
Liked: 129
I'VE looked almost everywere and it doesen't help that iam stupid too XD any help would be awesome. ty
E8500 @ 4.5
DD Torture Rack Build Log
See the deal is confront the cops at a Donut Shop and it totally screws them up.
10 Million+ Folding at Home points
Lemondrips is offline
post #2 of 7 Old 03-20-2008, 07:28 PM
the doctor
Quoted: 0 Post(s)
Liked: 399
Well which skin are you trying to use?
find skins at : http://customize.org/foobar
or the one EVERYONE uses cause it comes in a self installing EXE is fooAvA 1.04
Basically, you install the necessary components that are listed into the components folder
which is basically copying them from your download zip/folder and copying the .ddl files into
the components folder in C:\\program files\\foobar200. Then you install the skin and its imgs into the PanelsUI folder, which is once again clicking and dragging. Once thats done, reboot your foobar and hit "ctrl+P"
Click Display on the left column,
and change your "user interface module" to PanelsUI
the on the left again select the Panels UI submenu
and change the layout to the name of your skin :]
Lemondrips likes this.
Wibbly Wobbly, Timey Wimey.
phospholipid is offline
post #3 of 7 Old 03-20-2008, 07:30 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 119
They're all different and require you down download certain bits and pieces to make it work properly.
Just follow the directions the skin gives you.
Truambitionz is offline
post #4 of 7 Old 03-21-2008, 04:02 PM - Thread Starter
Audiophile
Lemondrips's Avatar
Quoted: 0 Post(s)
Liked: 129
the components folder in Crogram filesfoobar200. Then you install the skin and its imgs into the PanelsUI folder, which is once again clicking and dragging. Once thats done, reboot your foobar and hit "ctrl+P"
Iloveyou +rep
E8500 @ 4.5
post #5 of 7 Old 03-27-2011, 07:45 AM
Commodore 64
Deviatore's Avatar
Quoted: 0 Post(s)
Liked: 0
Which theme are you using Lemondrips?
If you browse skins in deviantart or customize.org, you will generally find installation instructions with them too.
P.S., After googling I found out some - foobar skins.
Deviatore is offline
post #6 of 7 Old 03-29-2011, 02:42 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 52
Are all of the foobar skins multiple windows? I want the application to be all in one window to avoid clutter, like Winamp.
Just the other day I starting standing up, but decided half way through I needed more than a piss. So after some fairly complicated acrobatics i got myself in the sit-down position, all without stopping and consistently hitting the bullseye. Needless to say, I was pretty pleased. smile.gif
Home Theatre: HT Omega Striker 7.1 S/PDIF out --> Onkyo TX-SR308 Receiver -->
Hsu HB-1 Mk2 (Fronts) + Polk Audio CS1 (Center) + Polk Audio Monitor 30 (Rears) + HSU STF-2 (Sub)
Arrec Barrwin is offline
post #7 of 7 Old 03-31-2011, 07:53 AM
Commodore 64
Deviatore's Avatar
Quoted: 0 Post(s)
Liked: 0
No, they all are single window themes
