OCN Speaker Club - Page 190 - Overclock.net
post #1891 of 3866 Old 01-24-2011, 11:26 AM
2.4ghz
Darkapoc's Avatar
Quoted: 0 Post(s)
Liked: 24
Those hifi bookshelf systems are a joke Sony makes some decently respectable Receiver/amps.
I can't die yet I just paid for next day air on parts!
Athlon II X4 OC Club
Darkapoc is offline
post #1892 of 3866 Old 01-24-2011, 04:43 PM
4.0ghz
drjoey1500's Avatar
Quoted: 0 Post(s)
Liked: 160
Originally Posted by Liighthead;12121301
hey got a question.
should i buy a 2.0/2.1 type thing.. with a amp ect all done n ready togo
OR
should i buy some speakers and make a box?
like 6.5" high
and maby 2 x 8" mids? idk depends what they got n for what price ect. pretty tight budget lol
but yeah what should i do? get speakers and make a custom box or just buy it already done ecT?
Buy prebuilt ones unless you have a bunch of free time to figure out what you're getting yourself into. TBH unless you're an electrical engineer you'll have to spend a decent amount of time designing the speakers (mostly figuring out what to do) and they probably won't come out sounding as nice as something designed by professionals.
What is your budget?
I'd suggest building something from here.
[Project] Reborn Legacy *Completed 6/13*
cool.gifHD202/Closed cirumaural mod cool.gif
RADEON::Ok, leaving now...
drjoey1500 is offline
post #1893 of 3866 Old 01-24-2011, 10:11 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
Originally Posted by Darkapoc View Post
Building it yourself could warrant a little extra money depending on what you get, but building your own also yields the best results usually.
8 inch drivers would be fine for low frequency reproduction however a 6.5 inch for highs would be a bit larger than what's needed unless you want the 8 inch drivers to act as subs.
Shoot more around the 3- 4 inch range.
I'm told that building the crossover for 3 way systems is a pain in the ass and two way is usually a better idea.
coreyL is offline
post #1894 of 3866 Old 01-24-2011, 11:33 PM
2.4ghz
Darkapoc's Avatar
Quoted: 0 Post(s)
Liked: 24
2 way is usually much easier.
But 3 way and up usually will provide for much better sound quality becase each speaker will have its' own separate range to recreate, instead of reacreating out of it's intended area.
Darkapoc is offline
post #1895 of 3866 Old 01-25-2011, 06:49 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 3
Hey everyone, i need some help!
I'm buying a new 5.1 system and I have no idea what I should be aiming for! I have about 800 euros to spend for the system + receiver, and the options I have avaible can be seen here:
http://www.4audio.rs/upload/File/4Au...bar%202010.pdf
http://www.audioplus.co.rs/wp-conten...28.05.2010.pdf
I've been recommended the following:
AVR - Yamaha Rx v 367
Speaker Systems:
-Canton Movie 80 CX
-JBL SCS 178
-Harman Kardon HKTS11 BQ
I'm leaning towards the HKs, however I dont know if I can get full potential with that receiver.
Source will be mainly 5.1 DTS Bluray rips in .mkv format from the HTPC via HDMI and PS3 Blurays...
I appreciate any and all input!
A child of five would understand this. Send someone to fetch a child of five. gunner2.gif
dejanribic is offline
post #1896 of 3866 Old 01-26-2011, 08:17 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
why would that matter if the woofer's intended range was 50-2000Hz and the tweeters intended range was 2000-22,000Hz?
coreyL is offline
post #1897 of 3866 Old 01-26-2011, 09:14 AM
2.4ghz
Darkapoc's Avatar
Quoted: 0 Post(s)
Liked: 24
Just because they CAN recreate those frequencies doesn't mean they do so well, mixing speakers together with others specifically designed for that frequency range Will clear up distortion and should greatly increase the amount of power the speaker can take by taking away said distortion from each individual speaker.
Darkapoc is offline
post #1898 of 3866 Old 01-27-2011, 02:25 AM
Commodore 64
Alorand's Avatar
Quoted: 0 Post(s)
Liked: 0
I was told you guys are the local audio experts.
For once I decided to invest in the quality of audio that my computer is putting out. So I bought Infinity TSS-800 speakers, and then learned that the amp in the subwoofer only powers the subwoofer, and I need a receiver to power my speakers.
Right now I am planning to buy Onkyo TX-SR508 7.1-Channel Receiver, and wondering if there is a difference in audio quality between using the motherboard's S/PDIF optical out or buying an audio card.
Alorand is offline
post #1899 of 3866 Old 01-27-2011, 02:28 AM
Retired Staff
pioneerisloud's Avatar
Quoted: 0 Post(s)
Liked: 1386
If you're using a digital signal.....a digital signal is a digital signal. It's all 1's and 0's. Onboard vs. audio card will be the same. The only difference is the features between them at that point.
Only time I ever recommend using an audio card is when you're using the analogue outputs, and speakers that need it (again, still using analogue outputs).
Alorand likes this.
Funny Quotes (Click to show)
Originally Posted by Syrillian
...I just ran in and... started ripping off the clothes I had on.
Originally Posted by steelbom
A GTX 580 is like a bear. AA or "small bunnies" don't really hurt it.
Originally Posted by Coolio831
Syrillian - Heroes get remembered, but legends never die!
How To: Install Car Audio to a PC Power Supply
¡¡¡ʍʇɟ qn1ɔ uoıʇɐıɔǝɹddɐ 939 ʇǝʞɔos ǝɥʇ
♫The♪Official♪Car♪Stereo♪Club♫
Pioneerisloud's 92 Prelude Si Build Log!!!!
pioneerisloud is offline
post #1900 of 3866 Old 01-27-2011, 02:37 AM
Commodore 64
Alorand's Avatar
Quoted: 0 Post(s)
Liked: 0
Thank you, that means since I will not be buying a sound card I actually have money to buy a receiver.
Any advice, or links to guides, on good receivers under $200, or what to look for when buying speaker wires and cables?
Alorand is offline
