[Official] OCN Headphones and Earphones Club - Page 1414 - Overclock.net
post #14131 of 38806 Old 03-28-2013, 08:30 AM
Audiophile
bumblebee1980's Avatar
Quoted: 0 Post(s)
Liked: 89
Xonar DG will be fine. Essence STX is a waste of money.
bumblebee1980 is offline
post #14132 of 38806 Old 03-28-2013, 08:39 AM
Audiophile
Quoted: 0 Post(s)
Liked: 89
I have owned a Creative, Asus and Auzentech sound card and none of them had any fidelity at all. the designs are so old. drivers are a pain in the ass. PCI express cards have way too many space, weight and power limitations. you can only do so much with a PCI express card. Asus was on the right track with the Essence One but it's poorly executed.
Xonar DG is a great little card for what it is but if you want fidelity you have to think outside the box.. literally.
post #14133 of 38806 Old 03-28-2013, 08:51 AM
OC'ing Noob's Avatar
Quoted: 0 Post(s)
Liked: 848
Originally Posted by Narokuu View Post
AS long as its not a crazy 800 dollar sound card, any Asus product will work, even if its 2 or 300 bucks.
If you only play indy games and LoL, I suggest you get a DAC which will sound much better musically. The problem with that is, unless you purchase a DAC/Amp combo unit, you will have to purchase a separate amp. An Asus DG sound card will come with an amp, but the music will not sound as good as if you were using a DAC. Ultimately it is up to you to decide, do you just want amplification and don't really care about audio quality or did you want your music to sound much better (restrictions apply)?
Overclock.net Mod of the Month 0109  Overclock.net 10 Year Member
OC'ing Noob is online now
post #14134 of 38806 Old 03-28-2013, 08:53 AM
Audiophile
Quoted: 0 Post(s)
Liked: 89
the Phoebus is just a repurposed Xense. Asus changed a couple things but it's virtually identical.
post #14135 of 38806 Old 03-28-2013, 08:55 AM
PC Gamer
Narokuu's Avatar
Quoted: 0 Post(s)
Liked: 18
i prefer to have just an internal sound card if i can, i dont know what DAC means, sorry im a noob at sound.
http://www.amazon.com/Beyerdynamic-DT-770-Pro-Headphones-Limited-Edition/dp/B008POFOHM these are 99% chance the headphones im geting, so if i can get away with just an internal sound card i would prefer that, im using a razer headset now, and listening to System of the down, and it sounds great to me, minus the outside noise, so im going to be impressed no matter what.
New To OCN? Click Here
Remember, Keep Calm And Carry Harder!
Chimp Challenge Participant
Narokuu is offline
post #14136 of 38806 Old 03-28-2013, 08:59 AM
Audiophile
Quoted: 0 Post(s)
Liked: 89
a DA converter is like a external sound card
you can try a Schiit Magni and Modi stack.
post #14137 of 38806 Old 03-28-2013, 09:02 AM
PC Gamer
Narokuu's Avatar
Quoted: 0 Post(s)
Liked: 18
So... i get an internal sound card, and then this? im confused guys
Narokuu is offline
post #14138 of 38806 Old 03-28-2013, 09:06 AM
Audiophile
Quoted: 0 Post(s)
Liked: 89
sound cards are better than on-board because they use higher quality chips, more space to design better stages, more power, separate power, etc.
DA converters are like the next evolution of that.
post #14139 of 38806 Old 03-28-2013, 09:08 AM
PC Gamer
Narokuu's Avatar
Quoted: 0 Post(s)
Liked: 18
OK can you guys suggest a nice setup like that for under 250 bucks or so? prefer one that will match the headphones you previously linked.
Narokuu is offline
post #14140 of 38806 Old 03-28-2013, 09:17 AM
Database Developer
liquidzoo's Avatar
Quoted: 0 Post(s)
Liked: 61
Schiit Audio Magni+Modi stack.
$198. You will need a couple of small RCA cables, but Schiit sells those too (though you could probably make some for lots cheaper if you know how to use a soldering iron). From what I hear it's excellent.
That or the O2+ODAC from JDSLabs. More expensive, but very highly recommended.
That said, I'm using the DT770s (80 Ohm, not the LE's) with a Xonar DG and I don't feel that I'm missing out on anything. That will change when I go to an external system I'm sure, but for now I'm very happy. I use my system for 100% music.
Edit: Added links
"Because perfect hair is overrated"
liquidzoo is offline
