[Sponsored]Project Thief - COMPLETED 11/13/2014 - 2 CPUs, 8 GPUs, 4 Loops, 6 Pumps, 50+ Fans, 2TB SSD - Page 214 - Overclock.net
post #2131 of 3824 Old 11-18-2012, 10:35 PM
eskamobob1's Avatar
Quoted: 0 Post(s)
Liked: 128
So long as its a single source I don't think it matters as much smile.gif... And for a review, I think the neutral was a good choice smile.gif)
WARNING: I have very minimal knowledge of photography so take everything I say with a grain of salt smile.gif
Favorite OCN Quotes (Click to show)
Look at it this way, opinions are like buttholes. everyone has one, and they all stink.
very pretty, love the dual frozxorz also.
Exactly! It's down right sexy!
eskamobob1 is offline
post #2132 of 3824 Old 11-20-2012, 02:24 PM - Thread Starter
King Iguana
stren's Avatar
Quoted: 0 Post(s)
Liked: 260
Well the reviews up, site rules say I can't link to it so you'll have to use your google skills. Or facebook of course.
Anyway I went to home depot and bought some acrylic and MDF for the test reservoir smile.gif I'll be working on it this afternoon hopefully!
Trouble-Maker
I write water cooling and case reviews but you'll have to use google because I can't link them here thumb.gif
stren is offline
post #2133 of 3824 Old 11-20-2012, 05:22 PM
4.0 GHz
TA4K's Avatar
Quoted: 0 Post(s)
Liked: 20
TA4K is offline
post #2134 of 3824 Old 11-20-2012, 05:37 PM - Thread Starter
King Iguana
stren's Avatar
Quoted: 0 Post(s)
Liked: 260
True to my word for once - I did some work on it, uploading pics nao...
Trouble-Maker
stren is offline
post #2135 of 3824 Old 11-20-2012, 06:12 PM - Thread Starter
King Iguana
stren's Avatar
Quoted: 0 Post(s)
Liked: 260
11/20/2012
Well it's been a while - I was busy working on my new website, the CaseLabs Merlin Preview, Spotswood Tech Station Review, the EK X3 Reservoir Preview, figuring out my new Nikon D5100 as well as finishing off the CPU Water Block roundup. I need a break but I'm almost done with all of that! Anyway - to celebrate not being fired yet I thought I'd work (finally) on the waterfall reservoir. This was originally inspired by Cyberdruid, however as he's retired I figured I'd have to make my own, and I suppose that's more fun anyway. I knew I would need a few attempts at this to get it right so I figured I'd make the prototypes out of MDF as it's cheap and easy to work with. So I went to the hardware and picked up a small board of MDF:
Dragged out my lonely tablesaw from the shed and got to work. I cut some 3x 3" strips of the 4ft side of the board:
I then measured the height of the 18 bays in the case and made the cut on one strip:
Then I test fitted in the case which meant undressing the drive bays!
Alright let's take that cover off:
Well that was fast, ok, drive bays next:
Resting the wood on the bottom of the drive bay gives me this much clearance which is about perfect:
So I cut the other side to the same size. Then measured and cut the top piece:
It's ok for both these pieces to be flush because they'll be some kind of joinery action going down. For now I'm thinking a finger joint. Maintaining strength while being able to knock it out on the table saw. I then cut a matching piece for the base so that all the frame pieces were cut:
I then started cutting the pieces that would form the waterfall itself:
Seven down:
Tablesaws make this quick. All done, sitting on the uncut acrylic sheet that will make up the front and back:
That's it for now!
Trouble-Maker
stren is offline
post #2136 of 3824 Old 11-20-2012, 07:26 PM
georgerm's Avatar
Quoted: 0 Post(s)
Liked: 0
Looks solid keep up the amazing work
georgerm is offline
post #2137 of 3824 Old 11-20-2012, 07:42 PM
Senpai Studios
derickwm's Avatar
Quoted: 0 Post(s)
Liked: 392
derickwm is offline
post #2138 of 3824 Old 11-20-2012, 08:02 PM - Thread Starter
King Iguana
stren's Avatar
Quoted: 0 Post(s)
Liked: 260
Originally Posted by derickwm View Post
Whoa. Work and stuff.
Seriously it's only been a year almost haha
Trouble-Maker
stren is offline
post #2139 of 3824 Old 11-20-2012, 08:06 PM
Senpai Studios
derickwm's Avatar
Quoted: 0 Post(s)
Liked: 392
Progress is good. Distract people from remembering I had a log at some point whistle.gif
derickwm is offline
post #2140 of 3824 Old 11-20-2012, 08:10 PM - Thread Starter
King Iguana
stren's Avatar
Quoted: 0 Post(s)
Liked: 260
So how's russia?
Trouble-Maker
stren is offline
