[Sponsored] WC'd M-ITX Build NoName [Updated May 1st] - Page 2 - Overclock.net
post #11 of 33 Old 03-04-2013, 06:15 PM
SLAPPA DAT BASS MON!
xxbassplayerxx's Avatar
Quoted: 0 Post(s)
Liked: 610
xxbassplayerxx is offline
post #12 of 33 Old 03-12-2013, 02:01 PM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
Not much progress been made in some time. I have been busy selling stuff so I can finance this project. I ordered Gigabyte Z77N-Wifi, Alphacool VPP655
and Alphacool HF D5 top for pump smile.gif I also have been made progress with fan controller and with its colour scheme.
I didn't like the original light blue backlight so I decided to change that to red. I tried different ways but I found this way best for me.
Here is the BitFenix Recon in it's original condition. It is nice but it's backlight isn't good for my case.
To disassemble this, only 4 screws needs to be removed from the corners to get it apart. Touch panel was glued to the front so I had to be careful to remove it so it wouldn't broke.
This is what it looks like without covers.
Next step was to get plastic film what I was going to use to make backlight red. Film wasn't red enough so I decided to use huge sharpie to color it more darker. But where is this going to be? I bet you will guess wrong.
Red film goes between backlight module and screen itself. I just slide the film between those and it goes there pretty smoothly.
And in my opinion it works great! smile.gif I left 5.25" metal piece out because I wont be needing it. Unfortunately as I was putting it together, I applied to much pressure in touch panel and heard the worst sound ever *SNAP* and touch panel was broken frown.gif I have requested new one from BitFenix so it will be in working condition when i need it smile.gif
Thanks to BitFenix for sponsoring my build
Markkedi is offline
post #13 of 33 Old 03-15-2013, 10:53 AM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
Woohoo! Got stuff today and got some done too!
IMG_6438.jpg?img=img900
From left to right. Alphacool VPP655T, Alphacool HF D5 Top and Gigabyte Z77N-Wifi
IMG_6439.jpg?img=img900
This time I'm going to work on the pump. For my surprise this one had tacho wire already on it. I just didn't like the wires on this so some sleeving is in order.
IMG_6441.jpg?img=img900
Also backside was not pleasing my eye and it needed to be changed.
IMG_6442.jpg?img=img900
For sleeving these wires I used sleeving that I got last year from modDIY. I also use this for most wires that I didn't get from BitFenix.
IMG_6446.jpg?img=img900
I started this by taking the lid off and taking fan & molex connectors off from wires too.
IMG_6450.jpg?img=img900
I didn't bother to take pictures of sleeving progress because it is boring But sleeved wires are here and I decided to change connectors to black ones too.
IMG_6453.jpg?img=img900
At this point I decided that I had to do something to the back lid.
IMG_6459.jpg?img=img900
I found some 3D carbon vinyl from my drawer and I just had to put it in there.
IMG_6461.jpg?img=img900
And to be honest, I am actually pretty proud how this pump and pictures turned out *Pads my own back*
Please tell me if you want something explained or photographed in more detail.
Markkedi is offline
post #14 of 33 Old 03-15-2013, 11:13 AM
Quoted: 0 Post(s)
Liked: 610
Isn't that board unable to overclock? Are you just using the WC system for looks/quietness instead of cooling?
Chimp Challenge Participant
post #15 of 33 Old 03-15-2013, 11:32 AM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
It lacks voltage control. It wasn't my first choice for this project but it was only one that I was able to get for my budget. I'm looking a better one in second hand constantly but not much of them are showing up in here. It will definitely be changed, maybe Haswell's come out rolleyes.gif
Markkedi is offline
post #16 of 33 Old 03-15-2013, 12:18 PM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
Oh and by the way, BitFenix contact person informed me that new fan controller is on the way thumb.gif In white but it doesn't matter to me smile.gif
Markkedi is offline
post #17 of 33 Old 03-15-2013, 12:39 PM
Quoted: 0 Post(s)
Liked: 610
Gotcha! If you're handy with a soldering iron, a volt mod shouldn't be difficult at all. If you want, I can help you figure out how to do it.
post #18 of 33 Old 03-15-2013, 01:01 PM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
Well that would be awesome! I just need to borrow better soldering iron and I should be good to go. With 10€ soldering iron I can fix TV's but motherboard might be little too hard biggrin.gif
Markkedi is offline
post #19 of 33 Old 03-15-2013, 01:12 PM
Quoted: 0 Post(s)
Liked: 610
The hardest part about soldering on computer components is the solder they use to place the parts. It's very high temperature stuff so it's difficult to get it to flow. Flux goes a long way in getting it all to work.
I do most of my soldering with a $4 Radioshack iron. My work is definitely better with a nice $100+ iron like a Hakko, but a cheap one should be fine.
post #20 of 33 Old 03-15-2013, 01:29 PM - Thread Starter
Case Modder
Markkedi's Avatar
Quoted: 0 Post(s)
Liked: 1
Need to test this mobo for a while first and see if it is ready to be modded wink.gif But I f you have any pictures or schematics I'd love to see them smile.gif
Markkedi is offline
