[SPONSORED] Hex Gear R40 - Frosted Dragon - Overclock.net
post #1 of 43 Old 07-28-2015, 09:05 AM - Thread Starter
MaTo84's Avatar
Quoted: 0 Post(s)
Liked: 0
Finally getting started on my Hex Gear R40 build.
I'm going with a red and black theme, witch will show by the compunents that I have chosen.
Specs:
Case: Hex Gear R40 (With frosted red accent pack)
Motherboard: MSi Z97m Gaming
CPU: Intel i7 - 4770K
Ram: 16Gb G.Skill TridentX 2400MHz
GPU: 2x GTX780Ti
Storage OS: 250Gb Samsung 840 EVO
Storage: 1Tb Samsung 840 EVO
PSU: Antec HCP-1000W
The watercooling will from EK and fittings from Bitspower. Put together witg PETG tubing from Nanoxia.
All the tubing will be done with at frosted finish to match the accents on the case.
The cables in this build will all be custom sleeved with Teleios sleeve from E22.
The four aluminium profiles, that form the corners of the case will be anodized black.
A couple of naked GPU's
The powerplant.
Some of the watercooling parts has allready arrived. Waiting for the rest.
Here is some pictures of how the tubing will look.
Finally, the eight countersunk washers that are going on the front and bach of the case.
MaTo84 is offline
post #2 of 43 Old 07-28-2015, 01:57 PM
Dalchi Frusche is offline
post #3 of 43 Old 07-29-2015, 02:30 AM - Thread Starter
MaTo84's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by Dalchi Frusche View Post
Sub'd
Also doing a Red and Black theme, just adding a little white. If you need some sleeving design examples, I posted a few on my build log here : [Build Log] Double Dragon
Cool, I have some ideers my self. But will defently tale a look at yours aswell smile.gif
MaTo84 is offline
post #5 of 43 Old 07-29-2015, 05:12 AM - Thread Starter
MaTo84's Avatar
Quoted: 0 Post(s)
Liked: 0
The link below is a great site to play with colors and designs. It's how I made so many so quickly.
http://choosemypc.net/sleeving/
MaTo84 is offline
post #6 of 43 Old 08-02-2015, 03:13 AM - Thread Starter
MaTo84's Avatar
Quoted: 0 Post(s)
Liked: 0
Just did some painting before leaving for holiday with the family.
Have not decided if the color is acceptable, I'll find out when I get to the assembly stage.
MaTo84 is offline
post #7 of 43 Old 08-03-2015, 06:05 PM
Case Modder
HackJoe's Avatar
Quoted: 0 Post(s)
Liked: 6
HackJoe is offline
post #8 of 43 Old 08-06-2015, 05:19 AM - Thread Starter
MaTo84's Avatar
Quoted: 0 Post(s)
Liked: 0
Also found some time to do some assembling, so that the GPU's dont have to be lying around naked biggrin.gif
And now, to the hardest component in the entire build to get my hands on, the Nvidia SLi brigdge smile.gif
MaTo84 is offline
post #9 of 43 Old 08-06-2015, 05:47 AM
post #10 of 43 Old 08-09-2015, 12:07 AM
FEAR.'s Avatar
Quoted: 0 Post(s)
Liked: 35
Lian Li Q06B - Mini ITX Build - 3570k@4.4GHz 1.24V | CM Hyper 212+ | Asrock Z77e-ITX | 16GB Kingston HyperX 1866MHz | ASUS R9 290 DirectCU II OC | XFX 650W XXX
New Zealand OCN Club
FEAR. is offline
