[SPONSORED] MILSPEC II-A Caselabs BH4 build. - Page 10 - Overclock.net
post #91 of 239 Old 07-22-2016, 07:49 AM - Thread Starter
Magoo made me do it.
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
Originally Posted by Benjiw View Post
I have one of those, they're alright! Decent fan for the price and moves a decent amount of air I reckon. biggrin.gif
I used mine to cool the back of my socket on the AMD rig.
No match for a 25mm on a rad tho,they literally were my last resort If I couldnt get the necessary spacing to thread the tube to the pass thrus.
As you say,the specs look usable tho.
Chimp Challenge Participant
B NEGATIVE is offline
post #92 of 239 Old 07-22-2016, 07:50 AM
Duality92's Avatar
Quoted: 0 Post(s)
Liked: 176
If only we could get decent static pressure 15mm fans. Then again, we're having a hard time with 25mm.
100 Million Folding Points  Foldathon Participant 2015  OCN Labs Reviewer
Duality92 is online now
post #93 of 239 Old 07-22-2016, 08:02 AM - Thread Starter
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
Static pressure is not the be all-end all metric,any half decent fan will work well,there are quite a few decent fans if you dont mind paying the money.
You can also look at 38mm fans,these blow 25mm fans away...quite literally. I had some UltraKazes that were awesome on a thick old skool GTX rad...if a little loud. You can help lesser fans with decent gasket sealing on the frame.
Sadly you cant get away from blade pitch = Pressure...which only a thicker fan will provide.
post #94 of 239 Old 07-22-2016, 08:18 AM
Overclocker in Training
Benjiw's Avatar
Quoted: 0 Post(s)
Liked: 93
Its a decent fan, nothing ground breaking but if you need to move some air it will do a nice job, can be a tad too loud for my ears though on full load but I'm a silence freak. biggrin.gif
Benjiw is offline
post #95 of 239 Old 07-22-2016, 04:26 PM
WaterCooler
Bogga's Avatar
Quoted: 0 Post(s)
Liked: 16
- Bulldogge Builds -
Done projects: Got milk? - Amphibious
In progress: New project coming soon
Bogga is offline
post #96 of 239 Old 07-23-2016, 01:57 AM - Thread Starter
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
It would of been perfect for the clearance issue if I hadn't could the right combo of extensions instead. I had to use a pair of dplugs in the end,the advantage of which is that i have -/+2mm of wiggle room.
Originally Posted by Bogga View Post
Progress will be fast,most of the metal work is cut,doing the final fitting and base paint by end of the weekend,it will certainly start to look more finished then. Ordered the stock and tooling for the res too,hopefully PARVUM will come thru otherwise I'm learning acrylic machining too....XD
post #97 of 239 Old 07-23-2016, 10:05 AM
WaterCooler
Bogga's Avatar
Quoted: 0 Post(s)
Liked: 16
Sorry if I missed where you wrote the answer to this... but why use two psu's instead of one more powerful?
Bogga is offline
post #98 of 239 Old 07-23-2016, 10:12 AM - Thread Starter
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
2 980Tis and a 6 core X99 wont run on just a 600w PSU..which is the largest SFX PSU available. The 700w Silverstone is just a little bit too long and still wont run it on its own.
post #99 of 239 Old 07-23-2016, 10:31 AM - Thread Starter
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
The roughing cutouts have been done,now to get the res made for the front and a more form fitting cutout for the GPU terminals/SLI bridge. I will machine that later today I think.....
After that...PAINT TIME!
I love the way I can see a lot of the hardware from 3 sides,so much so that clear coolant maybe the way forward.
5mm clearance from the top of the case to the GPU's......
post #100 of 239 Old 07-23-2016, 10:36 AM
Benjiw's Avatar
Quoted: 0 Post(s)
Liked: 93
Warning: Spoiler! (Click to show)
Hahaha, nice and tight! there is 2mm clearance from my fan on the 420 and the fan on my 360 rads in my Define S, scary close. biggrin.gif
Benjiw is offline
