Corsair H80 Performance Thread - Page 36 - Overclock.net
post #351 of 1192 Old 07-10-2011, 05:10 AM
Blameless's Avatar
Quoted: 1 Post(s)
Liked: 3130
I've had several i7 920s and even the best among them couldn't get to 4GHz on the stock cooler.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #352 of 1192 Old 07-10-2011, 07:37 AM
1.7ghz
Vandal4126's Avatar
Quoted: 0 Post(s)
Liked: 4
Yeah that site doesn't look right.
@mak1skav I recently cleaned out my rad and installed the scythe fans, My temps used to be about 5-7degrees hotter on load.
Really looking into the XSPC Rasa 240 kit. Been getting some info on installing it etc. It seems safe but I want to see how the H100 performs on a trusted review site.
Vandal4126 is offline
post #353 of 1192 Old 07-10-2011, 10:23 AM
Sem
Sem's Avatar
Quoted: 0 Post(s)
Liked: 1
extremely disappointing results especially since the H100 is only meant to be 2c cooler
my current 920 @ 4.2 @ 1.24v maxes out on prime at around 81c with my Megahalems and 1x GT AP-15
was looking to update to the H100 but if its only 2c better i think ill save the cash and maybe just get a 2nd AP-15 for my Megahalems
Sem is offline
post #354 of 1192 Old 07-10-2011, 01:20 PM
Hardware Dude
Quoted: 0 Post(s)
Liked: 454
Our tests were done internally with a controlled 25C ambient temp.
As I pointed out to the OP earlier, comparing your temps to other temps you see online really isn't viable for a few reasons.
1) Different ambient temps in the house/lab/etc.
2) Temp sensors are insanely inaccurate and cheap - a swing of 3-5C is completely reasonable when you aren't using the identical motherboard and chip (not the same model - the ACTUAL board/chip combo. Example - I killed a Rampage III in the lab, so we replaced it. All our temps were suddenly 4C hotter. No other hardware had changed.)
3) Different cases, airflow designs, internal ambient temps and airflow vary wildly and affect overall performance.
So while you can use them to gauge temps, saying "Wow, that cooler's awesome, it's 2C better than mine!" isn't really any good unless the review you're reading actually tests your cooler and the other cooler in the same exact test on the same exact hardware with the same ambient temps.
infected rat and _LDC_ like this.
CorsairGeorge is offline
post #355 of 1192 Old 07-10-2011, 04:20 PM
Amiga 500
Greenback's Avatar
Quoted: 0 Post(s)
Liked: 131
Originally Posted by Vandal4126 View Post
Why did you go for the Silver Arrow? It seems the Noctua performs far better on high OC's
going through different reviews they swap places so you wouldn't lose which ever 1 you have
Greenback is offline
post #356 of 1192 Old 07-10-2011, 04:24 PM
1.7ghz
Vandal4126's Avatar
Quoted: 0 Post(s)
Liked: 4
Going to wait for some official reviews on the H100. If it's not noticeably better then the H50 in push/pull then I'm going to go for the RASA 240 kit. Went through some install videos etc and it seems to be relatively safe and simple. Afaik if you use distilled water and silver killcoil you won't need to refill/clean the loop for 6-12months. Seen the reviews on the system and it seems to be 10-15degrees cooler then the top air units which is great for the price of only $129.
post #357 of 1192 Old 07-10-2011, 05:19 PM
Battlefield 1 Ready
kcuestag's Avatar
Quoted: 0 Post(s)
Liked: 334
What temperature improvement should I expect going from a Thermaltake FrÃ*o to a Corsair H80? Both stock fans at max speed.
As long as I get a +3ºC improvement that's great to me, I have an H80 coming home this week, might also add x2 Gentle Typhoon 1850RPM into them which makes it even better of an improvement over my FrÃ*o.
The "NoMoreUpgradesUntilXmasPC" Build Log
GPU's: HD5850 > HD5970 > 2x HD6970 > 2x GTX580 > 3x GTX580 >
> 2x GTX680 > 2x HD7970 > R9 290X > 2x R9 290 > GTX970 > 2x R9 290X >
> GTX980Ti > 2x GTX980Ti > 2x GTX1080 > 2x GTX 1080 Ti
Overclock.net - 2010 Foldathon Participant  Foldathon Folder - 2011 Participant  Foldathon Folder - 2012 Participant  Chimp Challenge 2 x Participant  10 Million+ Folding at Home points
kcuestag is offline
post #358 of 1192 Old 07-10-2011, 05:23 PM
PC Gamer
EM2J's Avatar
Quoted: 0 Post(s)
Liked: 14
Well I've never had a frio but I can tell you that the H80 performs about the same as an NH-D14.
When you get the H80, do try out those GTs and let us know how they perform.
ref evga gtx 680 w/backplate for sale 450$ shipped
Chimp Challenge Participant  2 Million+ Folding at Home points
EM2J is offline
post #359 of 1192 Old 07-10-2011, 05:29 PM
Battlefield 1 Ready
kcuestag's Avatar
Quoted: 0 Post(s)
Liked: 334
I had an NH-D14 and It was like 4-5ºC better than the Frío I currently have, that's awesome considering we're talking about stock fans. biggrin.gif
kcuestag is offline
post #360 of 1192 Old 07-10-2011, 05:30 PM
CDMAN's Avatar
Quoted: 0 Post(s)
Liked: 164
1 Million+ Folding at Home points
CDMAN is offline
