Corsair H80 Performance Thread - Page 49 - Overclock.net
post #481 of 1192 Old 07-13-2011, 03:27 PM
GMcDougal's Avatar
Quoted: 0 Post(s)
Liked: 67
Originally Posted by CorsairGeorge View Post
At the same RPMs, the H80/H100 fans will outperform the GT 1850s on our radiators.
H100 was pushed out by about 2 weeks, but they're flying over from China now to go out to reviewers. H80s have been sent out already I believe.
Sounds great. The h80 looks nice, but im very interested in the h100. My gut tells me its going to perform great, The only question i have is how noisey it will be.
Chimp Challenge Participant
GMcDougal is offline
post #482 of 1192 Old 07-13-2011, 03:32 PM
Case Modder
CattleCorn's Avatar
Quoted: 0 Post(s)
Liked: 39
Originally Posted by jamesaevans View Post
Hi CorsairGeorge,
Any insights on why there have been a lack of reviews of the H80 on the usual websites?
Thanks
James
CorsairGeorge, I'm curious about this too. What gives?
CattleCorn is offline
post #483 of 1192 Old 07-13-2011, 03:34 PM
Amiga 500
Greenback's Avatar
Quoted: 0 Post(s)
Liked: 131
Originally Posted by Vandal4126 View Post
I have a question about running the 4 fans push/pull out on the H100 rad. I have a CM690II case would it be better to run that setup with the rad mounted on the bottom of the case or the top? I don't think it would fit 4 fans on top without the fans touching the cooler/ram.
if you have the vents at the bottom to suck cool air in then it will be fine, I'm affraid I don't know much about the layout of the CM690II
EDIT: I would put a side fan on to help keep your gpu cool though
Greenback is offline
post #484 of 1192 Old 07-13-2011, 03:45 PM
Overclocker
beefdog's Avatar
Quoted: 0 Post(s)
Liked: 21
Just went to put my h80 on and one of the mounting screws broke right off
beefdog is offline
post #485 of 1192 Old 07-13-2011, 03:45 PM
PC Gamer
EM2J's Avatar
Quoted: 0 Post(s)
Liked: 14
Originally Posted by spinal_chord View Post
OK, just skipped to the test vs noctua. Am i missing something or were the temps taken when there was 0% load, thats what the pictures show ????.
I'd like to see pictures showing 100% load temps.
Dave.
It was indeed 100% load, said so in task manager. Idk why it doesn't show the CPU usage in realtemp (new to this stuff).
ref evga gtx 680 w/backplate for sale 450$ shipped
Chimp Challenge Participant  2 Million+ Folding at Home points
EM2J is offline
post #486 of 1192 Old 07-13-2011, 03:49 PM
333mhz
Quoted: 0 Post(s)
Liked: 0
Has anyone tried medium speed Yate Loons on the H80? I'm concerned about the noise of the H80 fans from the video posted to this forum. I don't mind trading a few degrees for a more silent system. I'm building a new SB system next week which I plan to OC to at least 4.5. Would the Noiseblocker M12-S2's be a better choice than the Yate Loons?
nitewulf is offline
post #487 of 1192 Old 07-13-2011, 05:08 PM
3.0ghz
Phos's Avatar
Quoted: 0 Post(s)
Liked: 32
The test versus the Noctua isn't really useful because of how much more noise the Corsair unit was allowed to make.
Phos is offline
post #488 of 1192 Old 07-13-2011, 05:12 PM
Battlefield 1 Ready
kcuestag's Avatar
Quoted: 0 Post(s)
Liked: 334
I think I will use the Gentle Typhoon 1850RPM with the H80 once it arrives.
I honestly can't stand the noise of the FrÃ*o fans at anything above 2000RPM, so I will probably hate the Corsair fans at 2600RPM...
How do the GT1850 fans work against Corsair fans both at ~1800RPM?
The "NoMoreUpgradesUntilXmasPC" Build Log
GPU's: HD5850 > HD5970 > 2x HD6970 > 2x GTX580 > 3x GTX580 >
> 2x GTX680 > 2x HD7970 > R9 290X > 2x R9 290 > GTX970 > 2x R9 290X >
> GTX980Ti > 2x GTX980Ti > 2x GTX1080 > 2x GTX 1080 Ti
Overclock.net - 2010 Foldathon Participant  Foldathon Folder - 2011 Participant  Foldathon Folder - 2012 Participant  Chimp Challenge 2 x Participant  10 Million+ Folding at Home points
kcuestag is offline
post #489 of 1192 Old 07-13-2011, 05:17 PM
1.7ghz
Vandal4126's Avatar
Quoted: 0 Post(s)
Liked: 4
CuriousGeorge already said their fans apparently run more quiet/push more air/have better pressure then the GTs @ 1800rpm or as he explained it "Balanced Mode".
Vandal4126 is offline
post #490 of 1192 Old 07-13-2011, 05:19 PM
Battlefield 1 Ready
kcuestag's Avatar
Quoted: 0 Post(s)
Liked: 334
Let's say I run the Corsair fans or the GTs 1850RPM.
Is it mandatory to run them plugged into the pump? Or can I pump them into my fan controller?
kcuestag is offline
