Cant get all the bubbles out of my loop - Overclock.net
post #1 of 8 Old 07-19-2011, 07:11 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 112
I've spent about a day and a half straight adding water and trying to get the air out of my loop to get my pump started. But I can't. Now I'm trying to put an 240mm rad with a OCZ Hydropulse 800, EK Supreme HF and a Swiftech MCRES into a Cooler Master 690, first gen. I have everything fitted pretty ghetto but the way the tubing is set up makes it difficult for me to shake the case and get all the bubbles out. I've literally flipped the case a dozen times. I'm not frustrated, just looking to speed up the process.
As you can see I put the radiator up top, and the pump and res in the cd drive bay. The CPU block, radiator, and pump tubing are all above the res, so I need help getting the bubbles out.
DONATE IN HONOR OF SYRILLIAN
August 13th, 2011. OCN remembers one of the greats.
I hope to meet you sometime when I take a visit to the big cloud in the sky. RIP Syrillian
Phenom II 945 4.005 GHzproof.gif <-first on OCN
Represent the 520!
TheOcelot is offline
post #2 of 8 Old 07-19-2011, 07:16 PM
nVidia Enthusiast
Ghostscript's Avatar
Quoted: 0 Post(s)
Liked: 113
Tap the blocks and tubing arround where the bubbles are, possibly when having the case put different ways. Except for that, it's patient I guess. Would help a little if you could shake the case a little as well, but see your issue there.
Ghostscript is offline
post #3 of 8 Old 07-19-2011, 07:18 PM
Quoted: 0 Post(s)
Liked: 200
make sure pump dose not get air. will add to problems. I just let it run should get it out and shaking it. But if u got platter drives not good.
GfhTattoo is offline
post #4 of 8 Old 07-19-2011, 07:21 PM
4.0ghz
spiderm0nkey's Avatar
Quoted: 0 Post(s)
Liked: 181
Tip your case around and squeeze the tubes. I sometimes run the pump for 5 seconds, shut it off, run it for 5 seconds and that can help clear the bubbles too.
R.I.P. Syrillian - August 13, 2011
I am a girl
No I will not make you a sandwich.
spiderm0nkey is offline
post #5 of 8 Old 07-19-2011, 07:59 PM
spitty13's Avatar
Quoted: 0 Post(s)
Liked: 11
add a DROP of dishwasher soap. This will create small bubbles that will eventually work themselves out. 1 drop only though
spitty13 is offline
post #6 of 8 Old 07-19-2011, 08:58 PM
Folding Fanatic
Quoted: 0 Post(s)
Liked: 162
On another note, cut out the perforated metal between your fans and the radiator, it destroys the airflow.
If more government is the answer, then it's a really stupid question.
HFM stats
EOC stats
Caleal is offline
post #7 of 8 Old 07-20-2011, 03:01 AM
PC Gamer
SgtMunky's Avatar
Quoted: 0 Post(s)
Liked: 72
Use a pin or needle to poke the bubbles through the tubing to burst them smile.gif
Nah actually don't do that. This looks like a pita though
SgtMunky is offline
post #8 of 8 Old 07-20-2011, 03:11 AM
4.0ghz
DirectOverkill's Avatar
Quoted: 0 Post(s)
Liked: 59
I leave reservoir opened for some time, pump on, pinch tube (because water presses many bubbles against the component walls), release....repeat and after 30 minutes bubbles are gone.
I hope that helps.
Smart is when you believe half of what you hear (read), brilliant is when you know which half to believe, yes? No?
DirectOverkill is offline
