Help on items for first time water cooler - Overclock.net
post #1 of 1 Old 08-15-2011, 12:54 PM - Thread Starter
333mhz
datamonarch's Avatar
Quoted: 0 Post(s)
Liked: 0
I am going to water cool my processor and gpus, and I have no idea on what pump, tubes, fittings, barbs, res, and heatsinks (gpu and cpu) I need. I have picked out the radiators and fans I will be using, since the RV02 is rather restrictive when it comes to watercooling. I am removing 2 of the bottom 180mm fans, and setting up a triple 120mm rad at the bottom, and am sticking a 120mm rad at the top exhaust. These are links to what I have piked out already.
http://www.frozencpu.com/products/12...tor_CG120.html
http://www.frozencpu.com/products/42...r_-_Black.html
http://www.frozencpu.com/products/61...2SM-124UB.html
http://www.frozencpu.com/products/92..._Acrylic_.html
The single 120mm is going to have 2 fans in push/pull with a fan shroud beneath, while the triple 120mm low profile will have 3 fans.
Prefferably, I would like to get universal vga waterblocks so I dont have to spend the money on that again.
Thank you in advance for the help! I am a bit lost and I'd rather not spend money on something I dont need.
datamonarch is offline
