1 Week of use and.. Already having to RMA Corsair H60 - Page 7 - Overclock.net
post #61 of 77 Old 10-11-2011, 09:36 PM
PC Gamer
kieran13's Avatar
Quoted: 0 Post(s)
Liked: 13
Originally Posted by slipee;15269961
Already bought the H60, and paid a lot for it tongue.gif what now?
are u screwing it down tight enough are u using ur hands or a screw driver
kieran13 is offline
post #62 of 77 Old 10-11-2011, 09:37 PM
somebadlemonade's Avatar
Quoted: 0 Post(s)
Liked: 107
maybe you should try it as an intake so you don't get the heat from the case running through the rad
somebadlemonade is offline
post #63 of 77 Old 10-11-2011, 09:38 PM
PC Gamer
kieran13's Avatar
Quoted: 0 Post(s)
Liked: 13
he already tried that i think
kieran13 is offline
post #64 of 77 Old 10-11-2011, 09:41 PM - Thread Starter
733mhz
slipee's Avatar
Quoted: 0 Post(s)
Liked: 3
Originally Posted by Flying Toilet View Post
Ambient temps will effect it. You're going to need better fans.
Already gone through this... I have CM R4's with 90CFM... The only improvement I can think about are Gentle Typhoons, and only to gain 10CFM, plus, they are not sold in Brazil...
slipee is offline
post #65 of 77 Old 10-11-2011, 09:41 PM - Thread Starter
733mhz
slipee's Avatar
Quoted: 0 Post(s)
Liked: 3
Hands first, screw driver until it cannot be more rounded
slipee is offline
post #66 of 77 Old 10-11-2011, 09:42 PM - Thread Starter
733mhz
slipee's Avatar
Quoted: 0 Post(s)
Liked: 3
Tried that already, the gain was about 1-2C.. Not effective
slipee is offline
post #67 of 77 Old 10-11-2011, 09:43 PM - Thread Starter
733mhz
slipee's Avatar
Quoted: 0 Post(s)
Liked: 3
Originally Posted by robwadeson View Post
Make sure the pump/block is not sitting on the capacitors on your mobo like this incident: http://www.techpowerup.com/forums/sh....php?p=2347251
and the fact that your idle temps are very good makes me think that it's not a defective unit.
Hmm thanks for the heads up, but I'm pretty much sure after several reseating tries, that the block is well-attached to the cpu
slipee is offline
post #68 of 77 Old 10-11-2011, 09:44 PM
PC Gamer
kieran13's Avatar
Quoted: 0 Post(s)
Liked: 13
ok im running out of ideas lol only thing i can think of now is the way the thermal paste was applied i remember i re seated my NH D14 about 6 or 7 times before i got it perfect the issue for me was not enough thermal paste i know how it sounds but a rice size drop is not enough i put about a 3x rice size drop in the center of the CPU
kieran13 is offline
post #69 of 77 Old 10-11-2011, 09:44 PM
733mhz
ar3f's Avatar
Quoted: 0 Post(s)
Liked: 30
Hmm, try to load the CPU, and keep a finger on the side of the rad (not in the fan to see if it gets warmer.
Maybe you did not prime the pump - forget that it's "sealed."
Try laying the machine on one side such that the rad is on top of the pump while the pump is spinning; well, any position that makes the air in the pump run up in the rad would do.
ar3f is offline
post #70 of 77 Old 10-11-2011, 09:47 PM
Linux Lobbyist
dhenzjhen's Avatar
Quoted: 0 Post(s)
Liked: 169
Too bad that H60 doesn't play nice. My 212+ beats that H60 then, lol!
At 4.4Ghz + HT on 1.418v my Idle is sitting at 32-39 and load gets up
to 82 max.
Chimp Challenge Participant  150 Million Folding Points  1 Billion Folding Points
dhenzjhen is offline
