H80 / H80i / H90 / H100 / H100i / H110 Case Compatibility Thread (Page 1 for full listings) - Page 36 - Overclock.net
post #351 of 1516 Old 03-08-2012, 11:13 AM
wolfgang91's Avatar
Quoted: 0 Post(s)
Liked: 1
Hi guys
NZXT SWITCH 810 is fully compatible with corsair h100 (push/pull mode whitout any mod). I'll get it soon, because of that.
I've spend a lot of time searching for a case, not too expensive, but corsair h100 push/pull compatible without mod, (HAF 932 it's, but I don't like the fact it hasn't any dust filter; Xigmatek elysium also it is, but it's too big and you'll have to buy usb 3.0 to header adapter, what makes it more expensive.)
NZXT is cool, and it's specifically designed to mount bigs radiators on top, in push/pull mode. You can put rads up to 360mm long and in NZXT website it's said that push fan + rad + pull fan can be up to 90mm thick.
The video isn't mine but I think it's very interestingthumb.gif (sorry if my English isn't very good)
Mattyd893 likes this.
wolfgang91 is offline
post #352 of 1516 Old 03-08-2012, 10:27 PM
PC Gamer
romanjaan's Avatar
Quoted: 0 Post(s)
Liked: 1
Just fitted the H100 into a NZXT Phantom 410 case with no mods at all push and pull, well half push actually. I have a crosshair v mobo so the mobo heat sink wouldnt let me add the the second fan in thebottom. So if you guys have a different mobo you can fit p/p in the case with no mods easily. Pics coming.
romanjaan is offline
post #353 of 1516 Old 03-08-2012, 11:09 PM
Overclocker
MME1122's Avatar
Quoted: 0 Post(s)
Liked: 94
So..the Arc Midi.
The H80 fits in the rear mount and obviously in the top. Will it fit in the front if you remove the top hard drive bay? How about in the bottom behind the psu? And are there similar sized rads for a custom loop that will fit?
And with a little modding you can remove the second hard drive bay. If I do that, do you think the H100 or a similar sized custom rad will fit in that front section?
MME1122 is offline
post #354 of 1516 Old 03-08-2012, 11:51 PM
Blizlake's Avatar
Quoted: 0 Post(s)
Liked: 124
Originally Posted by MME1122 View Post
So..the Arc Midi.
I think you should have asked from the fractal design club. But the answer to all the questions would be yes (if the hoses are long enough).
Blizlake is offline
post #355 of 1516 Old 03-09-2012, 12:18 PM
Intel Overclocker
sintricate's Avatar
Quoted: 0 Post(s)
Liked: 92
The H80 fits in the Silverstone FT03. See sig for pics.
i7 2600k 5GHz stable proof.gifPics of the SandBox build
You can't spell Mad without AMD.
sintricate is offline
post #356 of 1516 Old 03-11-2012, 09:31 AM
nVidia Enthusiast
Kolmain's Avatar
Quoted: 0 Post(s)
Liked: 31
Anyone know if the H100 fits in the Thermaltake MK-I Chaser?
Find me on Steam and Battlelog!
Chimp Challenge Participant  2 Million+ Folding at Home points
Kolmain is offline
post #357 of 1516 Old 03-11-2012, 09:49 AM
Quoted: 0 Post(s)
Liked: 120
gnolnats is offline
post #358 of 1516 Old 03-11-2012, 10:10 PM
Walk softly and carry a loaded Bolter
Sethy666's Avatar
Quoted: 0 Post(s)
Liked: 369
@ gnolnats
What type of temps do you get with your Q9650 with that setup?
40 Million+ Folding at Home points  Foldathon Folder - 2011 Participant  Foldathon Folder - 2012 Participant  Foldathon Folder - 2013 Participant  Chimp Challenge Participant X4  BGB Participant 2014  BOINC Pentathlon Participant x3
Sethy666 is offline
post #359 of 1516 Old 03-11-2012, 10:13 PM
axipher's Avatar
Quoted: 2 Post(s)
Liked: 268
Originally Posted by axipher View Post
I can't 100% confirm the H80 specifically, but the CoolIt Eco 120 mm Rad fits perfectly fine in the front of the Fractal Design Core 1000 in Push Pull, but you lost the vertical HDD mounting.
I was still able to mount 2 SSD's on the vertical HDD mount, and the HDD's in the optical drive bays.
So I see no problem with the H80 fitting in the Fractal Design Core 1000.
Confirmed 100% now in Fractal Design Core 1000
No pictures, but just upgraded my Coolit Eco to an H80 with push/pull AP-15's and a 10 1/4" GPU cooler with no problems.
Spoiler!
5 Million+ Folding at Home points  Chimp Challenge 2 x Participant  Foldathon Folder - 2012 Participant  BOINC Pentathlon Participant   Foldathon Participant 2015  Forum Folding War 2017
axipher is offline
post #360 of 1516 Old 03-12-2012, 08:52 AM
PC Gamer
brown bird's Avatar
Quoted: 0 Post(s)
Liked: 123
Just wanted to say thanks! Checked here before purchasing the H100. Rockin a Level 10.
Fear is Failure
brown bird is offline
