question on condensation - Overclock.net
post #1 of 6 Old 12-21-2011, 03:56 AM - Thread Starter
333mhz
_Nevets_'s Avatar
Quoted: 0 Post(s)
Liked: 1
Does anyone know what would happen if i ran water through a cpu water bock right at 32 degrees farenheit? pretty much ice water. think if maybe i just keep the case open and a fan on it it wont create moisture / corrode? i was thinkin of doin this once in a while for a lil suicide run. lolz
_Nevets_ is offline
post #2 of 6 Old 12-21-2011, 05:27 AM
PC Gamer
SgtMunky's Avatar
Quoted: 0 Post(s)
Liked: 72
If condensation is allowed to form, it could seriously damage your hardware. I can only recommend that if you wish to run liquid through a loop that far below room temperature, you will need to take precautions to prevent damage, such as insulating the surrounding motherboard, cpu socket, etc etc.
I do wonder though, if you keep a high air change rate inside the case, whether it will still create a problem. Humidity would affect it more than the air being still, shouldn't it?
SgtMunky is offline
post #3 of 6 Old 12-21-2011, 07:36 AM
Mongol's Avatar
Quoted: 0 Post(s)
Liked: 225
If you can maintain near freezing temps under load...condensation would occur pretty suddenly.
I'd recommend using a dehumidifier in your room as well as a fan blasting onto the board...even then, it would be a good idea to insulate around the socket.
_Nevets_ likes this.
GRENADE ALERT!!! GRENADE IN THE HOUSE! ABORT!! ABORT!!!
Mongol is offline
post #4 of 6 Old 12-21-2011, 10:52 PM - Thread Starter
333mhz
_Nevets_'s Avatar
Quoted: 0 Post(s)
Liked: 1
yeah thats what i was thinkin .thnx . this sounds like a cool idea .. i have a water chiller bucket thing .. from a cold water dispenser .. my idea is to run distilled water through the pump then the radiator with 3 fans then back over the chiller with ice water in the bucket and straight out to the cpu with a insulated tube ...
_Nevets_ is offline
post #5 of 6 Old 12-21-2011, 11:04 PM
No keyboard detected! Press F1 to continue..
Schmuckley's Avatar
Quoted: 0 Post(s)
Liked: 698
umm..if your case is upright..stuff a wadded up shirt over your video card...the tubing drips water ..you wouldn't want to do it all the time..
Schmuckley is offline
post #6 of 6 Old 12-23-2011, 03:46 AM - Thread Starter
333mhz
_Nevets_'s Avatar
Quoted: 0 Post(s)
Liked: 1
scotch brite sponge, yellow side up. thumb.gif LOL
_Nevets_ is offline
