Updated Final pics! Rampage IV Extreme + 3930K rebuild with 4-way SLI GTX580 - Page 3 - Overclock.net
post #21 of 68 Old 01-30-2012, 02:18 AM
WaterCooler
sawjai526's Avatar
Quoted: 0 Post(s)
Liked: 38
Originally Posted by Phatboy69 View Post
Yes even more so when you followed a guide and it turns out he highlighted completly the wrong resistor!
sawjai526 is offline
post #22 of 68 Old 01-30-2012, 02:39 AM
WaterCooler
Goof245's Avatar
Quoted: 0 Post(s)
Liked: 12
Originally Posted by sawjai526 View Post
The problem has already been fixed, and I believe the author had the offending PDF's pulled, and replaced with correct ones smile.gif
Goof245 is offline
post #23 of 68 Old 01-31-2012, 06:56 PM
WaterCooler
mBrane's Avatar
Quoted: 0 Post(s)
Liked: 0
Nice build, G! About the RAM blocks, which ones are you using? I just ordered a RIVE, and was very concerned that there wouldn't be room for blocks on the RAM.
Also, you mentioned that you're going to order the Koolance MB block (I had intended to go with EK). I saw an urban legend get squashed, where some folks thought that the Koolance block covered more MB components, but this turned out to be false. Was that your motivation?
What's your take on these 2 issues? Thx in advance!
mBrane is offline
post #24 of 68 Old 02-02-2012, 03:31 AM
Senpai Studios
derickwm's Avatar
Quoted: 0 Post(s)
Liked: 392
derickwm is offline
post #25 of 68 Old 02-02-2012, 03:48 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 41
I'm using aquacomputer ram blocks and the koolance mb block just looks better.
I am Intel of Borg. Resistance is futile. You will be assimilated. 990X Build Log
Rig Builder 3930K Build Log
Phatboy69 is offline
post #26 of 68 Old 02-03-2012, 07:35 PM
WaterCooler
mBrane's Avatar
Quoted: 0 Post(s)
Liked: 0
thinking.gif Serial? No way!
mBrane is offline
post #27 of 68 Old 02-03-2012, 11:29 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 41
Serial what? Ram blocks? Yes, because thats what makes sense for this ram layout. I used to have parallel but honestly the .1c difference in water temp is gonna make zero difference to ram.
The GPUs are in parallel though.
post #28 of 68 Old 02-06-2012, 06:46 PM
WaterCooler
mBrane's Avatar
Quoted: 0 Post(s)
Liked: 0
No, serial as in "serious?" Koolance blocks look better than EK? Just poking your sense of style, bro. poke.gif
mBrane is offline
post #29 of 68 Old 02-07-2012, 08:26 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 41
4x New 3GB GTX580 Gigabyte Ultra Durables are on their way to me with a Koolance R4E waterblock!
Cant wait to bench this!
post #30 of 68 Old 02-07-2012, 08:54 PM
Senpai Studios
derickwm's Avatar
Quoted: 0 Post(s)
Liked: 392
derickwm is offline
