Water cooling components assessment - Page 2 - Overclock.net
post #11 of 22 Old 04-10-2012, 11:58 AM - Thread Starter
Programmer
mvrb's Avatar
Quoted: 0 Post(s)
Liked: 1
I think I'll go for the PMP-450 with a top. I should be able to live without the vibration dampening pad as the PMP-450 seems better and cheaper.
mvrb is offline
post #12 of 22 Old 04-10-2012, 12:10 PM
WaterCooler
mm67's Avatar
Quoted: 0 Post(s)
Liked: 259
mm67 is offline
post #13 of 22 Old 04-10-2012, 12:13 PM
GingerJohn's Avatar
Quoted: 4 Post(s)
Liked: 853
True, I missed that on the list. Brain fart.
@OP, this is probably a better deal for you.
Inspiring Quotes (Click to show)
All of our new products will be carved out of styrofoam and painted to look like actual parts. And we will be tripling the price on everything. And closing customer service and tech support. Our new corporate motto will be "Too Bad, Jerks."
Console? just to play with friends and relax on the couch?
HAH! nice try Microsoft and Sony! I don't have any friends!
I want everyone to know that I kiss every CPU I install before sticking it in the motherboard
I'm actually somewhat annoying
I'm never sarcastic in the news section.
GingerJohn is online now
post #14 of 22 Old 04-10-2012, 12:55 PM - Thread Starter
Programmer
mvrb's Avatar
Quoted: 0 Post(s)
Liked: 1
Am I right about this:
http://www.highflow.nl/pompen/laing-swiftech/pompen-nl/alphacool-d5-vpp655-single-edition-no-top.html
^That is a pump that will accept the 3/8" tubing
http://www.highflow.nl/pompen/laing-swiftech/tops/ek-d5-x-top-g1-4-rev.2.html
^That is a top for the MCP-655 pump that will accept my 3/8" tubing (It won't fit on the PMP-450, right?)
mvrb is offline
post #15 of 22 Old 04-10-2012, 01:03 PM
WaterCooler
mm67's Avatar
Quoted: 0 Post(s)
Liked: 259
That Alphacool pump by it self will accept no kind of tubing since it comes without a top. Top is where you connect your fittings, one I linked has threads so you can use any kind of fittings with it. MCP655 and PMP450 have integrated 1/2" barbs as fittings, if you get one those you will have to remove stock and replace it with a top like that EK one. Both will work work but you will just pay extra for a stock top that you don't use.
mm67 is offline
post #16 of 22 Old 04-10-2012, 01:07 PM
GingerJohn's Avatar
Quoted: 4 Post(s)
Liked: 853
The VPP655, MCP655 and PMP-450 are all based on the same pump - the Laing D5
The VPP655 does not have a top - you need to buy either a top or a res that will hold it. As such it has no tube connections at all, and will not work as is.
The top that you linked has G1/4 threaded ports - it will work with any G1/4 fittings, like the ones that you linked in your first post. The top will fit all variants of the MCP655, VPP655, PMP-450 and Laing D5.
You can buy the VPP655, the EK top and use your fittings.
mvrb likes this.
post #17 of 22 Old 04-10-2012, 01:16 PM - Thread Starter
Programmer
mvrb's Avatar
Quoted: 0 Post(s)
Liked: 1
Hmm, ok. I am pretty sure that I will go with
Pump: http://highflow.nl/pompen/laing-swiftech/pompen-nl/koolance-pump-pmp-450.html
and
Top: http://www.highflow.nl/pompen/laing-swiftech/tops/ek-d5-x-top-g1-4-rev.2.html
and keep the 3/8" ID - 5/8" OD tubing.
Thanks!
mvrb is offline
post #18 of 22 Old 04-10-2012, 01:25 PM
PC Gamer
yanks8981's Avatar
Quoted: 0 Post(s)
Liked: 301
Get colored tubing and dont spent 23 USD on coolant when you could spent 1 USD on distilled water.
yanks8981 is offline
post #19 of 22 Old 04-10-2012, 04:00 PM
333mhz
bmxtom's Avatar
Quoted: 0 Post(s)
Liked: 0
The pump top would solve all your problem, but just wanted to ask if you are sure you have enough space to run the tubes without any rotary fittings or adapters?
bmxtom is offline
post #20 of 22 Old 04-10-2012, 06:06 PM
CMDPromptX's Avatar
Quoted: 0 Post(s)
Liked: 0
First, there is nothing wrong with your parts list in general (after the discussion that has taken place so far), but a quick question:
I know that your case (HAF 932) can fit a 120x3 rad in the top, but the Phobya rad is 60mm thick (which is as thick as a 360 comes), are you sure it will fit with the fans (60+25mm==85mm) in the top of your case? I don't own one so I'm not sure, but I know people that have made that mistake before on other cases.... Not all 360 rads are created equal.
Oh.. and coolant... ick.
Good luck!
CMDPromptX is offline
