need advice, i'm planning on upgrading my cooling (1090T) - Overclock.net
post #1 of 31 Old 04-22-2012, 08:29 AM - Thread Starter
733mhz
daemon7's Avatar
Quoted: 0 Post(s)
Liked: 0
i currently have a Corsair H50 as says in my sig
my chip isn't the greatest in the bunch but it's also not the worst (i think)
i have a cpu oc to 3.7ghz with 1.33v
and cpu/nb 2.4ghz at 1.162v *edited* (just a bit above stock v)
and both oc are quite stable
corsair h50 is only meant for 3.7ghz~ if you ask me, but i want to upgrade
i was messing around a while back with oc up to 4ghz, NOT stable trust me, because the temps were way too high. my cooling isn't good enough BUT (while keeping very close attention to temps) i needed quite high voltages to come near stability.
i forget exactly how much but i remember above1.5v!
that's quite high i believe, anyways
knowing my chip isn't one of the best, i don't want to get too expensive of cooling because my voltages need to be higher than average and well, the higher the frequency, even "more higher" the voltage needs to be, so is real good cooling (above $200) really cost effective?
i would love 4ghz, and of course more, but again i need higher than average voltages
so basically i'm trying to get advice to make a decision on how much i should invest in cooling
so what kind of cooling (and price) do you think i'll need to reach 4-4.2ghz with the type of 1090T chip that i have?
daemon7 is offline
post #2 of 31 Old 04-22-2012, 08:39 AM
richie_2010's Avatar
Quoted: 0 Post(s)
Liked: 175
1.6 v on your cpu nb.
my 1055t runs 1.15v on mine stock.
i think you need to start by reading ellgappos guide to overcloking
http://www.overclock.net/t/777378/official-gappos-little-deneb-thuban-overclocking-guide-with-too-many-smileys
as for a cooler the h50 is good but what are you looking to spend on a new one and where are you from?
richie_2010 is offline
post #3 of 31 Old 04-22-2012, 08:42 AM - Thread Starter
733mhz
daemon7's Avatar
Quoted: 0 Post(s)
Liked: 0
ok thanks, yea i thought stock because i went a couple notches above "auto" on cpu/nb v
is that not the same thing "near" stock?
i live in BC Canada
and i can spend max $200 but money is tight i'm gonna have to save up for a while but i would much rather pay less, all i want is 4ghz and hopefully 4.2ghz
daemon7 is offline
post #4 of 31 Old 04-22-2012, 08:47 AM - Thread Starter
733mhz
daemon7's Avatar
Quoted: 0 Post(s)
Liked: 0
oh sorry.. i made a mistake
it's not at 1.62v (my cpu/nb v)
it's at 1.162v
sorry! i am very tired
daemon7 is offline
post #5 of 31 Old 04-22-2012, 08:49 AM
rdr09's Avatar
Quoted: 0 Post(s)
Liked: 844
i agree with richie. that cpu/nb voltage should below your cpu vcore or close to it. for 2400MHz it should still be at stock.
use el gappo's guide as suggested. imo, a H100 with add'l fans will be your best option. no need to spend too much on our chips. get a good quality paste like the mx-4 or something.
edit: saw your edit. here's the club . . .
http://www.overclock.net/t/751576/1090t-owners-club
may i add, in case you don't know and if you have two sticks of RAM, make sure they are on the black dimm slots. better for oc'ing.
rdr09 is offline
post #6 of 31 Old 04-22-2012, 08:49 AM
Quoted: 0 Post(s)
Liked: 175
that sort of money is custom wc territory which if youi want you can go for but a air cooler would suffice.
could you link websites where you buy computer stuff from as im not fimiliar with stores in canada.
leaving the voltages on auto will mean that your board will decide what it thinks is best for your system now while at stock that maybe ok but when ocing that is a problem and i bet the 1.6 is causing your temp issues. revert all oc bact to stock for now.
as i said read that guide 1st and get all the software ready, we wont use amd overdrive just the bios as its easier.
( k voltage is ok then for nb)
post #7 of 31 Old 04-22-2012, 08:52 AM - Thread Starter
733mhz
daemon7's Avatar
Quoted: 0 Post(s)
Liked: 0
sorry i caused so much confusion heh
i don't really buy from sites i buy my computer stuff from a local guy that owns his own small shop but websites like www.newegg.ca is accurate
daemon7 is offline
post #8 of 31 Old 04-22-2012, 08:54 AM - Thread Starter
733mhz
daemon7's Avatar
Quoted: 0 Post(s)
Liked: 0
how are people getting 4ghz with the same cooling i have? what's wrong with my set up? the guy that set up my computer is very educated so i'm sure he used good glue and stuff but wow, if i can get 4ghz i'll be really happy haha, i wouldn't even bother with better cooling
what might be wrong?
daemon7 is offline
post #9 of 31 Old 04-22-2012, 08:55 AM
Quoted: 0 Post(s)
Liked: 175
sometimes smaller shops can have good deals but online stores can be cheaper especially since small shops have to mark up for their profit.
ah we all get confused sometimes
post #10 of 31 Old 04-22-2012, 08:58 AM
rdr09's Avatar
Quoted: 0 Post(s)
Liked: 844
the h50. better cooling will allow you to lower your vcore, thus higher oc. i think you answered your own question in the op.
rdr09 is offline
