any benifit to the bonneville? - Overclock.net
post #1 of 15 Old 10-26-2006, 05:14 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 124
Send a message via AIM to DanNEBTD Send a message via MSN to DanNEBTD Send a message via Yahoo to DanNEBTD Send a message via Skype™ to DanNEBTD
Why does everyone say the bonneville for car radiators? . . are there any larger one that could cool better? . . . i have a 240x240mm space to work with sooo . .
or coule i get two and have the outlet of one go into the inlet of the other . . .im only cooling my CPU . .for now.
Overkill doesn't exist on OCN. It's what we do.
DanNEBTD is offline
post #2 of 15 Old 10-26-2006, 05:19 PM
..the party can start now
Quoted: 0 Post(s)
Liked: 589
Send a message via MSN to Sideburns
the bonneville will probably cool your processor to almost ambient if that's all your using...as long as you use good components.
They recommend it, because it's good, it's common, and it's cheap.
Sideburns is offline
post #3 of 15 Old 10-26-2006, 05:31 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
Send a message via AIM to ira-k
1 single heater core is plenty for a cpu..I wouldn't hook one in front of another like that, you would be drawing hot air from the first into the second...Here's a Danger Den single, dont know if it's a Bonneville or not but it fit's your space requirments....Danger Den :: Radiators :: Heater Core Radiators :: Standard Heater Core with Fittings
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #4 of 15 Old 10-26-2006, 05:31 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 124
ok . . would i see any benefit if i used two? . . im using the componetes in the sig w/ 1/2" tubing . . (probably going w/ storm and mcp655) . . .
the reason i ask is because i have $50 store credit to discount auto . . which is conveinently just over two bonevilles lol
Edit>>
the two rads would be side by side so no hot air would be exchanged . . . they would be next to each other.
DanNEBTD is offline
post #5 of 15 Old 10-26-2006, 05:35 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
Send a message via AIM to Snerp
Edit>>
I think Dryadsoul has two in one system. The Heatercores are bigger than 120mm so if you only have exactaly 240mm two won't fit.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #6 of 15 Old 10-26-2006, 05:36 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
Oh yeah side by side would be fine..If you can use a double heatercore and just lay it on it's side would be best, fewer fitting's = less restriction...
ira-k is offline
post #7 of 15 Old 10-26-2006, 05:39 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
If you have the room there is always THIS Monster!
One single Bonneville HC will do you fine.
Snerp is offline
post #8 of 15 Old 10-26-2006, 05:43 PM
Quoted: 0 Post(s)
Liked: 589
Dude, that's awesome!!!!
post #9 of 15 Old 10-26-2006, 05:44 PM
4.0ghz
born2killU's Avatar
Quoted: 0 Post(s)
Liked: 166
Send a message via AIM to born2killU
wow snerp thats pretty cool
But the bonneville is cool too
I dunno
i think 2 would be overkill
born2killU is offline
post #10 of 15 Old 10-26-2006, 05:46 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
That's sick, I might have to get one!!!!..Good find Snerp!!!!
ira-k is offline
