what do you think - Overclock.net
post #1 of 7 Old 11-20-2006, 02:12 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 58
swayne is offline
post #2 of 7 Old 11-20-2006, 02:13 PM
splat00n's Avatar
Quoted: 0 Post(s)
Liked: 86
Originally Posted by swayne View Post
no
splat00n is offline
post #3 of 7 Old 11-20-2006, 02:14 PM
You're a Loose Cannon, Bobrovsky!
pow3rtr1p's Avatar
Quoted: 0 Post(s)
Liked: 570
Only potential issue I see is upgrading, it may be really hard to add VGA blocks or to change the CPU block. I would say buy it in parts, or one like the Swiftech you posted yesterday (at least I'm pretty certain that was you) or else you're stuck having to buy a whole new kit if you want to upgrade.
pow3rtr1p is offline
post #4 of 7 Old 11-20-2006, 02:58 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
I'm super Creal when I say...no.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #5 of 7 Old 11-20-2006, 03:04 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 316
Yeah, dont do it, if you are cheap just buy really cheap parts so you can upgrade one by one. Don't go for the kit as it is somewhat hard to upgrade with as others have mentioned before. If you need help post something in the WC section with your budget and we can help you out planning a good budget setup.
Chopes is offline
post #6 of 7 Old 11-20-2006, 03:14 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 21
a lot of people hate WC kits. I think it really depends on how new you are to it. I have only done one WC system( using an upgraded TT big water kit) It has been very realiable, no leaks , and all around good cooling butI also have it in a Armor case with 4 120mm and 1 250mm fans not including the ones on the RADs of wich I have three. I doing a new dual loop system of all dangerden/swifttech parts now in a mozart case... I would say that if you go with a kit go with one that is essintatly just a bunch of parts of a normal WC system not one that is entirely pre built as I think this one is. that way you get the experince to do your next system the right way.
or just buy swift/danger at the outset and do it slowly. with all the help you can find here you will have a easy time of it.
Baran is offline
post #7 of 7 Old 11-20-2006, 03:27 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
No....Here is a nice Swifty kit for cheap.....It really is a good one.. And it's about $50 bux cheaper then the regular price...Swiftech Apex Ultra H20-220
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
