[Build Log] Monstas Inside! (Monsta rads, custom MM case, Titan SLI) - Page 25 - Overclock.net
post #241 of 577 Old 02-06-2013, 10:45 AM - Thread Starter
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
Originally Posted by tsm106 View Post
EK backplates are nice since they do double duty by removing some latent heat off the vrms.
Yup, the 7970 and 7950 backplates passively cool the vrm from the back of the gpu. I know ppcs.com has the "classic" (aka non-csq) 7950 backplates; thoughts if they will fit the 7970? (questioning the vrm positions though, ???)
wermad is offline
post #242 of 577 Old 02-06-2013, 04:44 PM
num1son's Avatar
Quoted: 1 Post(s)
Liked: 114
Seriously though Wermad the CSQ isn't really that horrible once you see it in person. Not amazing, but you'll be able to live with it. Get the black ones and you'll hardly notice it all. thumb.gif
num1son is offline
post #243 of 577 Old 02-06-2013, 04:57 PM - Thread Starter
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
HK (copper/ss) + backplates + bridge: $680 + s/h
AC (copper/ss) + backplates + bridge: $640 + s/h
EK (copper/acetal) + backplates + bridge: $570 + s/h
Leaning on EK but ppcs doesn't have any backplates in stock. Frozencpu has the blocks and the plates, but not the bridge. If I buy the blocks and bridge at ppcs and the backplates at frozen, it'll be ~$15 more. Still pretty good prices. Shame EK doesn't do a quad plexi bridge frown.gif
wermad is offline
post #244 of 577 Old 02-06-2013, 05:06 PM
Jeffinslaw's Avatar
Quoted: 0 Post(s)
Liked: 184
Would you still like me to measure the distance from block to block for you?
Jeffinlaw
*EDIT* I did anyways and it's about 25mm from block to block with one slot between.
Jeffinslaw is offline
post #245 of 577 Old 02-06-2013, 05:09 PM - Thread Starter
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
Jeffinlaw
I doubt my D-plugs will fit....so no need to bother any more. I missed out on Koolance refurb 7970 blocks for $69 each frown.gif. Might as well get EK since they have everything I need and its priced right. Ugh, now I want to change my cpu block too.......
wermad is offline
post #246 of 577 Old 02-06-2013, 05:10 PM
Jeffinslaw's Avatar
Quoted: 0 Post(s)
Liked: 184
Bahhh you're too fast, I just edited my post. And that means you should get a new CPU block too so it matches wink.gif
Jeffinslaw
post #247 of 577 Old 02-06-2013, 05:31 PM
WaterCooler
King4x4's Avatar
Quoted: 0 Post(s)
Liked: 98
Won't touch CSQ since you can't use D-Plugs with them!
Chimp Challenge Participant  Foldathon Folder - 2013 Participant
King4x4 is offline
post #248 of 577 Old 02-06-2013, 06:25 PM - Thread Starter
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
Jeffinslaw
Lol, thanks any bud but if you do have them, won't hurt to have that info thumb.gif. I'll scour ebay for a used one but tbh, the DD has been very impressive and i like the mounting system smile.gif
Well, they perform good and the price and packaging is good. Its the looks that are...ugh....thinking of them makes me wth.gif. Anyways, Gotta keep the costs down and that will score me some points with the missus biggrin.gif
wermad is offline
post #249 of 577 Old 02-06-2013, 10:53 PM
Graphics Card Aficionado
tsm106's Avatar
Quoted: 0 Post(s)
Liked: 1381
You don't want d-plugs with CSQ because CSQ bridges have a quad semi-parallel. I guess that's ek's carrot to get one to go CSQ, crop circles ftl.
Chimp Challenge 2 x Participant
tsm106 is offline
post #250 of 577 Old 02-06-2013, 11:01 PM - Thread Starter
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
The d-plugs would have gone with the Koolance blocks. Looks like I'm going ek csq w/ a quad bridge, so that means the d-plugs will be up for sale smile.gif
Only quad bridge is acetal. Wish they would have made a clear/frosted one to match the blocks I'll be getting frown.gif
edit: there's an ek link they call a bridge. it basically gives you vertical top and bottom ports. The link included converts the bottom only ports to horizontal ones. This is for the regular bridges to link cards. Think of these links as the ones HK and AC use (the acetal/pom pieces).
Its very confusing but I don't need these extra link-bridges since I'm going with a bridge.
wermad is offline
