Planning a Drain Valve - Overclock.net
post #1 of 5 Old 12-18-2012, 09:17 AM - Thread Starter
WarChild's Avatar
Quoted: 0 Post(s)
Liked: 1
Hi friendly people of OC.net,
So i am now planning a drain valve, i got myself the Koolance Threaded Female/Male Quick Disconnects for draining purposes.
Should i get this Y-splitter to create the drain port?
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_346_393_623&products_id=24908
Intention is to connect the Koolance Female quick disconnect to the single end of the Y while my loop will run as per normal on the top 2 ports of the Y splitter. When i want to drain the loop, i will attach a draining tube connected with the Male quick disconnect and plug it in to the female side to drain the system.
How does this sounds? Please help. Thanks
WarChild is offline
post #2 of 5 Old 12-18-2012, 11:33 AM - Thread Starter
WarChild's Avatar
Quoted: 0 Post(s)
Liked: 1
Need help on this.
WarChild is offline
post #3 of 5 Old 12-18-2012, 02:34 PM - Thread Starter
WarChild's Avatar
Quoted: 0 Post(s)
Liked: 1
Any ideas?
WarChild is offline
post #4 of 5 Old 12-18-2012, 02:47 PM
Quoted: 0 Post(s)
Liked: 127
Use a T instead of a Y, and have it at the lowest point in the loop. The rest is just whatever fits and looks how you want it to. I personally do not have experience with QDCs to know if they may drip in the long term (depends on how good their seals are). Most people that do drains, use a T and valve, but a QDC should be fine so long as it doesn't leak.
Electrocutor is offline
post #5 of 5 Old 12-18-2012, 02:54 PM
rdr09's Avatar
Quoted: 0 Post(s)
Liked: 844
doesn't really matter whether you use the y or t fitting. neither will hinder flow. y might let you direct the drain better when space is limited.
rdr09 is offline
