Corsair H100i high temps - Page 5 - Overclock.net
post #41 of 42 Old 07-31-2013, 01:51 PM
FromWhitin's Avatar
Quoted: 0 Post(s)
Liked: 1
i forgot to mention, i use a pull configuration with the standard fans, i use a corsair 600t and the radiator is mounted inside the case at the top and the fans are in the top, so the is that metal with holes between them, not sure if that affects performance allot, problem is, with my motherboard(asrock extreme4 z77) i cant mount them both in the case, the heatsink is in the way
FromWhitin is offline
post #42 of 42 Old 08-13-2013, 12:56 PM
PC Gamer
pruik6's Avatar
Quoted: 0 Post(s)
Liked: 7
Send a message via Skype™ to pruik6
I got the sane before , i did fix it by doing this: When i mounted my backplate from my h100i to my motherboard there were a gap between the backplate and the motherboard. So i did 2 1/2mm rings between it can be different on your system so be carefull maybe you need 1 or not any.
I did get normal temps as it should be ,you can try to do it aswell. For me it was the gap between motherboard adn the backplate:thumb:
My english is bad ,I know I try to Improve every forum post.
If you not understand what i type say it and i edit it hopefully to more logic English thumb.gif
pruik6 is offline
