Watercooling a Node 304 - All Done! Pictures and Videos Included - Page 2 - Overclock.net
post #11 of 57 Old 02-22-2013, 11:50 AM
ZealotKi11er's Avatar
Quoted: 6 Post(s)
Liked: 1787
Originally Posted by Cyclops View Post
If only I knew how to braid cables. Is it hard to learn? What about the equipments that I would need? I think if I braid the cables myself, I wouldn't need to buy the short cable kit as I can cut them to whatever length I deem fit.
Custom length game will take a lot of time to make. The short cables lengths are good enough.
CPU History (Click to show)
CPU -> Sempron 2400+, Athlon 64 3700+, Core 2 Q6600, A8-3870K, Core 2 Q9550, Core 2 QX9770, Core i7 920, Core i5 2500K, Core i5 3570K, Phenom II X4 955, Core i7 3770K.
GPU History (Click to show)
FX 5200 128MB, 9800 Pro 128MB, 6800GS 256MB, 7600GT 256MB, HD 4850 512MB, HD 4870 1GB, 2x HD 4870 1GB, GTX280 1GB, HD 5850 1GB, GTX470 1.25GB, GTX580 1.5GB, HD 6950 2GB, HD 6950 2GB + HD 6970 2GB, HD 6990 2GB, HD 7970 3GB, 2 x HD 7970 3GB,R9 290 4GB, R9 290X 4GB, R9 Fury X 4GB, GTX 1080 8GB, GTX1080 Ti 11GB
MB History (Click to show)
ECS KN1 Extreme -> ASUS P5Q-E -> GIGABYTE GA-X58A-UD7 -> GIGABYTE GA-Z68XP-UD4 -> GIGABYTE GA-Z77X-UD5H -> ASRock Z77E-ITX
Chimp Challenge Participant  Overclock.net 10 Year Member
ZealotKi11er is offline
post #12 of 57 Old 02-22-2013, 03:57 PM
333mhz
goshawn's Avatar
Quoted: 0 Post(s)
Liked: 10
goshawn is offline
post #13 of 57 Old 02-22-2013, 04:52 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 686
Originally Posted by goshawn View Post
You can get custom length braded cables here:
http://www.bitfenix.com/global/en/products/premium-modding/alchemy-cables/
But those are extensions and I'm already tight on space.
If you're taking rounds in the sternum, it's telling you your cover is insufficient
Cyclops is offline
post #14 of 57 Old 03-08-2013, 02:14 PM
Eljiyx's Avatar
Quoted: 0 Post(s)
Liked: 0
You should be aware that this PSU http://www.silverstonetek.com/product.php?pid=351&area=en doesn't come with short cables, you need to buy this extra short cable set http://www.silverstonetek.com/product.php?pid=219&area=en . Just so you don't buy it and think something is wrong or anything.. smile.gif
Eljiyx is offline
post #15 of 57 Old 03-08-2013, 02:31 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 686
Already bought the short cable kit smile.gif.
Cyclops is offline
post #16 of 57 Old 03-08-2013, 08:01 PM
SOCOM_HERO's Avatar
Quoted: 0 Post(s)
Liked: 47
SOCOM_HERO is offline
post #17 of 57 Old 03-12-2013, 05:27 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 686
These are the final parts, video coming soon.
Main Parts:
Fractal Design Node 304
Intel i5 3570K
EVGA NVidia GTX 670 (Reference)
Asus P8Z77-I Deluxe
Samsung 840 Pro 256 GB
Hitachi GST Deskstar 7K1000.D (1TB, 7200 RPM, 32MB Cache, 2.5")
8 GB (2 x 4GB) Samsung 30nm DDR-3 Low Profile
Silverstone ST45SF-G 450W
Silverstone PP05 Short Cable Kit
Water Cooling Parts:
XSPC Rasa
XSPC GTX 670 Water Block
XSPC GTX 670 Back Plate
XSPC Compression Fittings
Switftech MCP355 VDC Pump
Hardware Labs Black Ice GTX Gen Two Xtreme 184mm (2 x 92mm) Radiator
4 * Cooler Master Blade Master 92mm Fans
Magicool 120mm Slim Radiator
Cougar Vortex CF-V12HP 120mm Fan
PrimoChill PrimoFlex PRO LRT Tubing (White, 3/8 ID, 5/8 OD)
Cyclops is offline
post #18 of 57 Old 03-12-2013, 05:28 PM
Gone
adridu59's Avatar
Quoted: 0 Post(s)
Liked: 313
Subbed! Good luck with all that stuff!
OCN's Recommended: Power SuppliesAudio Products
~ Sig now ToS compliant
adridu59 is offline
post #19 of 57 Old 03-12-2013, 06:04 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 686
Thanks. They're all already in. Just ordered some Quick Disconnects for a home made sort of reservoir that I can get rid of once I've filled the loop. Just not enough space inside for a permanent one.
Cyclops is offline
post #20 of 57 Old 03-12-2013, 07:11 PM
Intel Overclocker
ivanlabrie's Avatar
Location: Buenos Aires, Argentina. Land of the obscenely expensive hardware
Quoted: 0 Post(s)
Liked: 342
Nice Cyclops...not familiar with those 92mm fans, but coming from you they must be good, huh? thumb.gif
ivanlabrie is offline
