Swiftech H220/H320/H220X/H240X/H140X and CM Glacer 240L/360L Owners' Club - Page 1962 - Overclock.net
post #19611 of 20904 Old 06-11-2016, 10:23 AM
outofmyheadyo's Avatar
Quoted: 0 Post(s)
Liked: 55
I tried them full speed, no thanks, way way to loud for my taste.
outofmyheadyo is offline
post #19612 of 20904 Old 06-11-2016, 10:26 AM
Intel Overclocker
Quoted: 0 Post(s)
Liked: 367
No one said to use them at full speed. There are places between "all" and "nothing". Those places can be set up to meet the demands of the system in the way that suits you best.
ciarlatano is online now
post #19613 of 20904 Old 06-11-2016, 10:38 AM
Quoted: 0 Post(s)
Liked: 55
I fail to see how fan curve would help me, over a fixed RPM of wich is the maximum noise level I can tolerate? ( wich is barely audible )
post #19614 of 20904 Old 06-11-2016, 03:52 PM
Scrimstar's Avatar
Quoted: 0 Post(s)
Liked: 8
Scrimstar is offline
post #19615 of 20904 Old 06-11-2016, 05:16 PM
Nick-F's Avatar
Quoted: 0 Post(s)
Liked: 7
I would say you do not need it if you have good quality coolant ( Mayhems , EKollant , etc )
Nick-F is offline
post #19616 of 20904 Old 06-11-2016, 05:31 PM
Scrimstar's Avatar
Quoted: 0 Post(s)
Liked: 8
I kinda want to get a pearl pastel, they look so awesome
3.25mm is smaller than the hole right? silver coil looks kinda big to be 3.25mm wide
post #19617 of 20904 Old 06-11-2016, 05:53 PM
Nick-F's Avatar
Quoted: 0 Post(s)
Liked: 7
yes 3.25 mm is only about 1/8th of an inch . As you can see I agree with you about the Pastel coolant , mine is the EK Ekoolant pastel blue .
Nick-F is offline
post #19618 of 20904 Old 06-11-2016, 06:05 PM
Intel Overclocker
Quoted: 0 Post(s)
Liked: 367
Originally Posted by Scrimstar View Post
Will this fit and help in the H320x2
https://www.amazon.com/Silver-Coils-Antimicrobial-999-Strip/dp/B00A66HMRC/
You would only need a coil if you are running straight distilled water.
Pearl pastel? If you are talking about Aurora, I would suggest you read the Aurora Wiki. It is made for show use a day or two at a time.
post #19619 of 20904 Old 06-11-2016, 06:31 PM
Scrimstar's Avatar
Quoted: 0 Post(s)
Liked: 8
I would probably have to empty the propylene glycol coolant mix, and clean all of it right; if I wanted to use pastel concentrate. (don't know how to clean it)
I don't know what is a good mix. I want something that is white (maybe teal), and won't need much maintenance.
https://www.ekwb.com/shop/ek-ekoolant-pastel-white-concentrate-250ml
http://www.performance-pcs.com/mayhems-pastel-coolant-1-liter-uv-white.html#Specifications
post #19620 of 20904 Old 06-12-2016, 05:30 AM
mfknjadagr8's Avatar
Quoted: 0 Post(s)
Liked: 96
low maintenence and dyes are two words that are not synonymous....dyes break down over heating and cooling cycles and clog things up...they must be maintained more often than say distilled with colored tubing....also be careful of the dyes you use as swiftechs warranty doesn't cover certain ones
mfknjadagr8 is offline
