[ Build Log ] Tj11 My Way - Overclock.net
post #1 of 10 Old 03-15-2013, 11:24 PM - Thread Starter
1.3ghz
CD69Scorp's Avatar
Quoted: 0 Post(s)
Liked: 53
Hi, thought maybe it’s about time I started a log for my Tj11 build.
I have gotten to where it’s up and running, but still have a lot that still needs to be done before I consider it done.
Now for why I chose this case, I had a couple of friends that tried talking me into moving into this case from my Sniper when it first came out. I thought it was a beautiful case but for some resin I just didn’t like the way the motherboard sat and the two fans on the mid-plate. I looked at almost every case out there, and there are some beautiful cases. But none had the look and elegance that I was looking for (in my mind anyway).
Then I saw the Murderbox MKll and I knew that was basically what I wanted. I wasn’t going to spend that kind of money on that case, even though I think I have spent about that or more on this case with tools and all. I thought about using the Tj07 but that case has been modded every way possible already. I looked for any other Tj11’s that had the motherboard rotated but couldn’t find any, I’m sure there is one but no luck. I was hoping to get some ideas. The Tj11 also has a lot more room.
My goals for this build were…
Rotate motherboard 90 degrees and stall be able slide out the motherboard tray
Rotate drive cage 90 degrees
Stealth as much of the wiring as possible
Try out Acrylic tubing
Fit a radiator up top
Use no rivets, all threaded screws
Figure out a way for subtle indirect lighting
Redo side panel
I will do this in steps as the build progresses. I have a lot of pictures but will try to keep it to a minimum.
Here is where I am at now…
CD69Scorp is offline
post #2 of 10 Old 03-15-2013, 11:24 PM - Thread Starter
1.3ghz
CD69Scorp's Avatar
Quoted: 0 Post(s)
Liked: 53
post #3 of 10 Old 03-15-2013, 11:33 PM
MORE POWER!!!
deafboy's Avatar
Quoted: 0 Post(s)
Liked: 430
Yeah, I am watching this....
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
Deafboy's Rack
2 year anniversary In Remembrance of a Great - RIP Syrillian
What it means to max a game out (Click to show)
1) All in game settings are as high as they can go, AA include, EVERY setting is MAXED out.
2) Average FPS matches or exceeds the max refresh rate of your monitors, ideally I'd like to say minimum matches but that's just near impossible to guarantee.
3) Game is being played at the native resolution of your monitor(s)**
**can be said that you are maxing a game out at __ resolution as long as you state that resolution and pass the first 2 criteria
deafboy is offline
post #4 of 10 Old 03-15-2013, 11:35 PM
WaterCooler
TwentyCent's Avatar
Quoted: 0 Post(s)
Liked: 11
TwentyCent is offline
post #5 of 10 Old 03-16-2013, 12:30 AM - Thread Starter
1.3ghz
CD69Scorp's Avatar
Quoted: 0 Post(s)
Liked: 53
Ok, lets start with the motherboard rotation. It took a while to do this but it was actually easier than I thought.
Test fitting motherboard to back of case looks good so far. Had to do a little trimming.
It was after this cut that I bought a jig sew lol
The bottom track already had threaded holes in it. It was just a matter of placing it and drilling holes in the mid-plate. There was also a threaded hole on the back of the track that I was able screw it to the back of the case and give it more stability. The end gets chopped off later.
I was trying to figure out how to mount the upper track with some kind of bracket when I got to looking at the hot swap bays that was at bottom of the case and found this bracket.
I couldn't have come up with anything better. The only problem was mounting the track to it. The box shape of the track made it so I couldn't get screws though it, so had to do some cutting.
And works better than I thought it would. I will do some trimming and fitting as the build progresses but I think it turned out pretty good.
post #6 of 10 Old 03-16-2013, 12:35 AM
Case Modder
GREG MISO's Avatar
Quoted: 0 Post(s)
Liked: 66
So you basically turned a tj-11 into a monster tj-07? I approve of this! Subbbed thumb.gif
-Greg
V-Dubbin since nineteen thirty somethin!
Air-cooled
Arizona Overclockers Club
"The only club that overclocks with an ambient of 120f"
GREG MISO is offline
post #7 of 10 Old 03-16-2013, 12:41 AM - Thread Starter
1.3ghz
CD69Scorp's Avatar
Quoted: 0 Post(s)
Liked: 53
I quoted in your log that you gave me some ideas that I was going to run with, hope like. Thanks
Originally Posted by TwentyCent View Post
Thank you
post #8 of 10 Old 03-16-2013, 01:59 AM
MORE POWER!!!
deafboy's Avatar
Quoted: 0 Post(s)
Liked: 430
I very much like.
That "made in china" needs to go away though, lol.
Deafboy's Rack
deafboy is offline
post #9 of 10 Old 03-16-2013, 02:03 AM - Thread Starter
1.3ghz
CD69Scorp's Avatar
Quoted: 0 Post(s)
Liked: 53
post #10 of 10 Old 03-16-2013, 02:12 AM
xv13tlaclo1x's Avatar
Quoted: 0 Post(s)
Liked: 5
“Your time is limited, so don’t waste it living someone else’s life.”
-Steve Jobs
xv13tlaclo1x is offline
