[Build Log] H U L K S M A S H - Page 9 - Overclock.net
post #81 of 114 Old 04-19-2013, 11:08 PM - Thread Starter
INCREDIBLEHULK's Avatar
Quoted: 0 Post(s)
Liked: 113
wasn't expecting any untill tomorrow!
Sadly, looking at the way I'm going to do the loop, that top's outlet might make me use more tubing than I want and the outlets both being on one end make it a bit more difficult
Guess i'll take some extra time searching and planning as I don't want to order anything on the weekend anyhow
Edit
dumb question of the night tongue.gif Would putting a right angle fitting right at the outlet of the top cut more pressure than a right angle anywhere in the loop?
INCREDIBLEHULK is offline
post #82 of 114 Old 04-20-2013, 12:21 AM
Stickeelion's Avatar
Quoted: 0 Post(s)
Liked: 64
A right angle is fine on the outlet just make sure the inlet has a straight fitting otherwise the balance of the impeller will be affected.
Don't be worried about pressure unless every single one of your fittings is a right angle. You'll be fine mate thumb.gif
Stickeelion is offline
post #83 of 114 Old 04-20-2013, 01:48 AM
Jakusonfire's Avatar
Quoted: 0 Post(s)
Liked: 552
Many pump tops have a 90 degree turn leading to the impeller and they work fine.
Jakusonfire is offline
post #84 of 114 Old 04-20-2013, 03:05 AM
Quoted: 0 Post(s)
Liked: 64
Jakusonfire, I learn't that from martin, If you don't take it from the man himself I don't know who you can believe, His post saying that is here
post #85 of 114 Old 04-20-2013, 03:29 AM
Magoo made me do it.
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 777
Laing stock DDC.
I also have a 90 inlet on my D5 strongs in series and it makes no measurable difference in performance,however you can get airlocks easier and it can get noisy during the bleeding process.
B NEGATIVE is offline
post #86 of 114 Old 04-20-2013, 04:11 AM
Quoted: 0 Post(s)
Liked: 552
I didn't say there was no truth to it, just pointing out that its not uncommon to be arranged that way
On the bitspower D5 top water can come in the top inlet, turn 90 deg and hit the impeller. I had my EK D5 top set up with a 90 feeding into the front inlet and didn't notice any problems.
post #87 of 114 Old 04-20-2013, 10:15 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 113
post #88 of 114 Old 04-21-2013, 12:09 AM
Quoted: 0 Post(s)
Liked: 64
First choice I would go for the EK one, Looks good and is the best performing top out there. BTW that thing on the top is a stop covering an alternative outlet.
Second choice, Bitspower, not quite as much performance improvement, doesn't look as good but It has 4 ports, (one more than the EK) which makes it more versatile. You can also use the bitspower mod kit with it to make your pump with bling. (you can't use that kit with any other tops)
Third Alphacool
All tops will still give you a significant power increase though
post #89 of 114 Old 04-21-2013, 01:41 AM
sakerfalcon's Avatar
Quoted: 0 Post(s)
Liked: 44
The Bitspower top has 5 ports, with an inlet at the bottom also.
sakerfalcon is offline
post #90 of 114 Old 04-21-2013, 06:44 AM
Quoted: 0 Post(s)
Liked: 64
My mistake, Thanks for correcting me sakerfalcon
