watercooling the Antec skeleton - Overclock.net
post #1 of 12 Old 04-18-2013, 04:11 AM - Thread Starter
austin8868's Avatar
Quoted: 0 Post(s)
Liked: 0
Hey guys i was wondering if its possible to add a watercooling setup with the Antec skeleton? I have seen people mount the h50 on the side which i could do but is there something i could put in the two internal 3.5" bays? Its just open space and i figured i could make some good use of it. Apart from having the h100 in my last build im a complete noob when it comes to watercooling. thanks!
austin8868 is offline
post #2 of 12 Old 04-18-2013, 04:40 AM
Amiga 500
Greenback's Avatar
Quoted: 0 Post(s)
Liked: 131
with that case you could put a 240 on the side with a small res pump in the drive bay depending on what you want to cool you could get a rad stand
Greenback is offline
post #3 of 12 Old 04-18-2013, 05:43 AM - Thread Starter
austin8868's Avatar
Quoted: 0 Post(s)
Liked: 0
I would just be cooling my cpu. I have a 7970 that gets pretty good temps already. I guess I might watercool it in the future, just not now.
post #4 of 12 Old 04-18-2013, 07:48 AM
Amiga 500
Greenback's Avatar
Quoted: 0 Post(s)
Liked: 131
well tbh if your only doing cpu and may add gpu then I'd suggest the swiftech h220 for now then expand it later if you need to
post #5 of 12 Old 04-18-2013, 09:21 AM - Thread Starter
austin8868's Avatar
Quoted: 0 Post(s)
Liked: 0
It's a little expensive ($250?) Do i have to buy an extra things with it or is everything needed included? Can it only cool the cpu?
Anything i can use this with? I have all my cables sleeved red so this would match nicely
http://www.ebay.com/itm/XSPC-RayStorm-CPU-Water-Liquid-Cooling-Block-SPECIAL-RED-VERSION-Intel-/111044510346?pt=US_Water_Cooling&hash=item19dac4c28a
post #6 of 12 Old 04-18-2013, 09:38 AM
Nomad692000's Avatar
Quoted: 0 Post(s)
Liked: 9
If you want that then grab a XSPC kit and get red led instead of the blue ones.
“There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.”
- Ernest Hemingway
"These things I do, that others may live"
R.I.P. Ian Murdock
ApricityOs The new Distro on the block
Nomad692000 is offline
post #7 of 12 Old 04-18-2013, 10:01 AM - Thread Starter
austin8868's Avatar
Quoted: 0 Post(s)
Liked: 0
Id like to fit everything inside if possible. If i understand correctly a pump & reservoir will fit in two 5.25" bays? I only have two 3.5" bays open. Anything i can make work with that?
post #8 of 12 Old 04-18-2013, 10:08 AM
Quoted: 0 Post(s)
Liked: 9
Swiftech make a micro rez its pretty small. Several other companies maks smaller rez's. Here is a 3,5 inch bay rez, another one.
- Ernest Hemingway
R.I.P. Ian Murdock
post #9 of 12 Old 04-18-2013, 10:26 AM - Thread Starter
austin8868's Avatar
Quoted: 0 Post(s)
Liked: 0
I like the 2nd one since it would take up both bays. What else would i need to buy with that?
post #10 of 12 Old 04-18-2013, 10:42 AM
Quoted: 0 Post(s)
Liked: 9
Fittings is the only thing I can think of.
- Ernest Hemingway
R.I.P. Ian Murdock
