First time watercooling, critique component list! - Overclock.net
post #1 of 12 Old 05-15-2013, 05:57 PM - Thread Starter
mattar's Avatar
Quoted: 0 Post(s)
Liked: 0
Hello,
I've only recently discovered overclock.net when i began reading about watercooling guides. I must say it's an exceptional site!
Not long ago, I built my first rig and as of late, I've been looking to transition towards watercooling.
I've been doing lots of reading and was hoping to get some feedback on current list of items I intend to purchase.
Current spec:
3570k
Powercolor 7970 (AX7970 3GBD5-2DHV3)
ASRock Z77 EXTREME4
I will also be looking to get the 900D case prior to the implementation of the watercooling system.
Components:
CPU block: EK-Supremacy CPU Water Block - Full Nickel - CSQ
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_971_498_490&products_id=34841
GPU block: Swiftech KOMODO-HD7970 Full Cover VGA Waterblock
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=33923
Radiator: EK-CoolStream RAD XTX (480)
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_457_667_668&products_id=32497
Radiator: EK-CoolStream RAD XTX (240)
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_457_667_668&products_id=32495
Pump: Koolance PMP-500 G1/4 BSP High-flow Pump
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=35715
P mount: EK-DCP Mounting Plate Kit
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_439_770&products_id=27770
Reservoir: EK-RES X3 250 Reservoir
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_318_659&products_id=35998
Tubing: PrimoFlex Advanced LRT 10ft Tubing - 7/16in. ID X 5/8in. OD
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=36345
Fitting (x12): Bitspower Premium G1/4" Black Matte High Flow 7/16" ID (5/8" OD) Compression Fitting
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_346_393_614&products_id=26556
Fitting (x4): Bitspower G 1/4" Matte Black Rotary 90 Degree IG 1/4" Adapter
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_346_393_611_629&products_id=27723
Power Distribution (x2): ModMyToys 8-Pin Power Distribution PCB - 8-Way Block
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=32854
Fans (x12): Rosewill RFA-120-BL 120mm 4 Blue LEDs LED Case cooler
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835200049
Please forgive me if I've made a mistake as this is completely new to me. I opted to go dual 480's as I plan on going CF. Also I wasn't 100% sure about fittings but everyone seemed to rave about the Bitspower components. Any suggestions of items that i may need or could assist me (such as mounts or something of such nature)...
Any help is appreciated.
mattar is offline
post #3 of 12 Old 05-15-2013, 06:06 PM - Thread Starter
mattar's Avatar
Quoted: 0 Post(s)
Liked: 0
Perhaps I misunderstood but I thought that once you start adding a 2nd or 3rd gpu that a sole 480 would be insufficient?
mattar is offline
post #4 of 12 Old 05-15-2013, 06:08 PM
cruisant's Avatar
Quoted: 0 Post(s)
Liked: 7
If you're in Canada, go for Dazmode or NCIX. http://www.dazmode.com/store/ thumb.gif Add an Iwaki RD30 and San Ace 38mm fans for that built smile.gif J/K
cruisant is offline
post #5 of 12 Old 05-15-2013, 06:10 PM
Amiga 500
smex's Avatar
Quoted: 0 Post(s)
Liked: 172
since sandy bridge the cpu´s make much less heat.. ok you got ivy, but your heat problem
( if it will bother your chip) will come due the bad engineering of intel and not due the lack
of radiators.
you can blind take two 360´s. but ok now you said a 3rd gpu and so on. this might be ok then,
especially if you live in hot areas. but it was not that clear to me that you want to add a 3rd gpu.
ah... now i see, canada. then you dont need any cooling at all! haha just kidding.
my guess would be that even for 3gpu´s 2 x 360 will do the job.
do you plan massive overclocking tha video cards?!
smex is offline
post #6 of 12 Old 05-15-2013, 06:14 PM
Folding Fanatic
lowfat's Avatar
Quoted: 0 Post(s)
Liked: 452
I would suggest some sort of heatsinks for the VRMs on the GPU. That mounting plate will not work w/ that pump.
lowfat is offline
post #7 of 12 Old 05-15-2013, 06:20 PM - Thread Starter
mattar's Avatar
Quoted: 0 Post(s)
Liked: 0
of radiators.
No massive overclocking so to speak. But this is why I'm here asking for feedback in the first place smile.gif. Probably will go with 2x 360
Would it work if I got an EK pump?
mattar is offline
post #8 of 12 Old 05-15-2013, 06:21 PM
Overclocker
Quoted: 0 Post(s)
Liked: 7
Hey,
I would suggest that you get a full cover block for your graphics card rather than a universal block. Although a universal block can be reused for later graphic cards you would have to get separate heatsinks for the GDDR5 VRAM and for the VRMs. A full cover block will cost a bit more but it will cool the entire card.
fil1p is offline
post #9 of 12 Old 05-15-2013, 06:31 PM - Thread Starter
mattar's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by fil1p View Post
Hey,
How about this?
Can't find anything else since my card my card is non-ref.
Card # is listed in first post regarding specs.
mattar is offline
