Fan questions - Overclock.net
post #1 of 2 Old 05-21-2013, 11:51 AM - Thread Starter
Kdman's Avatar
Quoted: 0 Post(s)
Liked: 3
I have a few questions I have a kraken x60 and I would to buy different fans for it that produce less noise at the same airflow, and I have found a fan which would be AWESOME for this.... It is the prolimatech pro usv14 fan it is really quiet at maximum airflow which is 98cfm at 19db. But there is one problem and that is that it is a 140 mm fan with 120mm mounting holes. I was wondering if anyone knows of some adapter to make this fan work, because it also have really high static pressure which is what I need for the rad.
Kdman is offline
post #2 of 2 Old 05-21-2013, 12:26 PM
Quoted: 0 Post(s)
Liked: 127
Consider manufacturer specs on fans to be nearly useless in open-air use and completely useless in radiator use. I've not personally tried this fan though, so it's your gamble.
There are 120mm to 140mm adapters, but I've not seen one that just has reduced screw positions.
Electrocutor is offline
