[Build Log] ~ FUSION ~ TJ07 modded by FOB - Page 4 - Overclock.net
post #31 of 34 Old 08-13-2013, 06:25 AM - Thread Starter
Ishinomori's Avatar
Quoted: 0 Post(s)
Liked: 61
Cheers for the kind words guys
Originally Posted by Jeemil89 View Post
Looks great man thumb.gif I was thinking I should by this case also. Looks so good.
I don't know what you're fotographing with, but take the pics outside (or inside) in natural light and avoid flash. This will give you better colors and pics.
Thanks mate, i need to get better at taking pictures, perhaps i need some sort of lamp or something, i am taking the pictures on a Lumix waterproof 14mp camera. tongue.gif
Originally Posted by DerComissar View Post
Having the res. close up to the window looks cool, as a benefit for making room for the cpu to rad tube.
Good plan for a bay cover to mount the res. to.
Perhaps if you get that custom acrylic top panel designed and made accordingly, you could go with your dual-fan idea.smile.gif
Edit:
I forgot to mention, the fill port idea. Like you, I didn't want to ruin the clean lines of the top by putting a fill port and cap on the top. I also considered boring a hole through the acrylic top on mine. But the res was fairly close to the top of the case, so I decided to go for it, and drill the fill port hole directly over the res. top port. It may not look as cool as no port, but it sure is nice to have for filling the loop.
I may even be able to get my backplate design on the top panel, if that is the case, i wont have room for the fillport, i could really do without it though if i can get awesomely clean lines on the top panel, with fan shrouds built in.
Ok, i also have the idea that i could get a lighted panel with "FUSION" cut out of it here.
Also had another delievery today!
Cheers,
Ishi
Ishinomori is offline
post #32 of 34 Old 08-13-2013, 06:47 AM
DerComissar's Avatar
Quoted: 0 Post(s)
Liked: 215
That's likely the best way to go then, no fugly fill port, for the custom fan shroud panel to look right.thumb.gif
Edit:
And the lighted Fusion logo, another unique touch.
Lots of fans there! Already sleeved too.
DerComissar is online now
post #33 of 34 Old 08-13-2013, 07:39 AM - Thread Starter
Ishinomori's Avatar
Quoted: 0 Post(s)
Liked: 61
Then again, i've changed my mind bout the fillport, had a quick go at google sketchup.
My ideas for the shroud atm
post #34 of 34 Old 08-16-2013, 12:54 AM - Thread Starter
Ishinomori's Avatar
Quoted: 0 Post(s)
Liked: 61
Yikes, 20mm acrylic is pricey!!! :/
